4wd shifter attachment - JeepForum.com
post #1 of 7 Old 10-10-2011, 10:15 AM Thread Starter
bluedaffy
I may be using a lot of wrong terminology here cause I'm not too familiar with mechanic jargon but I'm working on it, so please bear with me.
I was riding off-road on some family property yesterday and I approached a small downed log that my wrangler couldn't crawl in 2wd so I went to put her in 4 (btw- this was my first time using 4wd on my jeep and I just would assume it would work fine). But it didn't work fine, it didn't go into 4wd at all and the 4wd shifter didn't feel right, I could move it into the different positions but it didn't feel like it locked in and would just freely move around.
Fast forward to today, I crawled under there to test my auto-common knowledge and found that the metal bar coming down from the shifter was not attached to the bar coming out of the transfer case (I'm assuming this is the majority, if not all of the problem I'm having)
...but the way they connected looked confusing the me for just and elbow shaped hinge. The male end on the metal bar coming down from the shifter wasn't threaded and had a rubber piece hugging the protrusion. How is this bar supposed to connect to the other bar. In other words, what pieces will I have to buy to re-attach these two bars?
Thanks so much,
Bluedaffy
bluedaffy is offline
post #2 of 7 Old 10-10-2011, 11:13 AM
kloppk
Yup - that should be connected to the bar from the tcase.
Pop the plastic bushing off the hanging "L" shift rod and insert it into the lever on the tcase is the same orientation (swing the arm up to see which way it should go before popping it off the "L" arm.
Put a dab of oil on the protrusion on the "L" arm and pop it into the plastic bushing in the tcase lever.
I usually use a pair of Channle Locks to help push it in.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #3 of 7 Old 10-10-2011, 12:09 PM Thread Starter
bluedaffy
Great, thanks so much. Should I be concerned about the bushing being damaged or faulty because it already came off once and will do it again? Or does this kind of thing happen from time to time?
post #4 of 7 Old 10-10-2011, 12:55 PM
jhumphrey
The piece of rubber sticking out of the tcase shifter handle is called the shifter isolator. I just had to replace it in my YJ. If that piece of rubber isnt properly seated, it will allow the handle to pop off completely. There is a write up on how to permanently fix this problem. It does involve using a welder and such.
Pull your tcase shifter off and see if the metal clip is in there. You should see a 4 pronged clip between the actual handle and the rubber piece. The "teeth" of that metal clip grips the notches on the tcase's "straight" handle. On the side of the L shaped handle, you will see that the metal clip inside has two tabs that are supposed to lock the metal clip onto the handle.
Its a crummy design to start with.
jhumphrey is offline
post #5 of 7 Old 10-10-2011, 01:07 PM
fishnic
not to hijack the thread, but what is the shift pattern to go into 4 high and 4 lo? My shifter doesnt have the pattern on the knob, and straight back isnt working. (88 2.5L)
fishnic is offline
post #6 of 7 Old 10-10-2011, 01:08 PM
jmmorgan82
2009 JK Wrangler
Should be 2hi-4hi-n-4lo
jmmorgan82 is offline
post #7 of 7 Old 10-10-2011, 01:11 PM
jmmorgan82
2009 JK Wrangler
And OP, not sure if this would help you or not, but here is a pic of the linkage I found online:
4wd , 4wd hardware , transfer case
can anyone ID this attachment.?? biofish Wrangler General Discussion 2 08-28-2011 04:12 PM
What might this vac attachment do? schwim YJ Wrangler Technical Forum 8 07-20-2011 09:33 AM
YJ Soft Top Attachment baudencm YJ Wrangler Technical Forum 3 05-12-2010 03:55 PM
Tow Strap Attachment Sooner1 TJ Wrangler Technical Forum 6 05-22-2005 06:36 PM
bikini top attachment texan YJ Wrangler Technical Forum 8 02-26-2004 03:36 PM
