4wd shift fork stuck help!! - JeepForum.com
post #1 of 3 Old 11-14-2013, 07:00 PM Thread Starter
AviciiLevels
Doing the nylon spacer fix in my vac shift motor. I cannot get the shift fork off the shaft of the vacuum motor. The vacuum/shaft itself slides halfway out of the shift housing. Is there a seal/groove holding the shift fork on?
I removed the 3 e clips as well. the shift fork will not budge the final inch off the shaft. Is the last part of the shaft a bigger diamaeter or what is going on? please help!
AviciiLevels is offline
post #2 of 3 Old 11-14-2013, 08:28 PM Thread Starter
AviciiLevels
Pic
post #3 of 3 Old 11-15-2013, 08:58 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Looks tweaked. Put it back together and twist it around. Rotate the shaft underneath with a set if channel locks and try that.
Luck Favours The Prepared
Anticanman is offline
