4wd not working. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4wd not working.
RIGID LED Light Blowout Sale - All Sizes, All Series, all Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Wrangler Bushwacker Flat Fender Flare Sale at Baselin
Unread 11-14-2014, 01:37 AM   #1
Caboose89
4wd not working.
Ive got an 89 YJ sitting on 35" Goodyear Mtr's, with a locker in the rear. Today it dumped a good five inches of snow so naturally I went ahead and threw it in 4WD but noticed no change in traction. If you have ever driven a RWD jeep with a locker in the rear in snow, you know that it sucks and doing cookies is easier than keeping the dang thing straight.
I know the usual vacuum leak on the front axle but the PO put in a posi lock cable to bypass the vacuum leak problems so I know that this is not the reason it is not working. When I put it in 4lo the tcase still goes to a lower gear and the front drive shaft spins as it should but the front tires are not spinning. To test this theory I put it up against a curb put it in 4Wd and floored it. The back tires spun but the front stayed stationary. Only budging when I occasionally caught traction in the rear.
Tomorrow I will be tearing into it to see if I can find anything out of the ordinary, but what do I need to look for? Could the shaft collar connecting the two shafts be seized up? Could the fork have broken in some way? Could it be because I am low on gear oil? Any insight or shared knowledge on the subject would be much appreciated. My jeep used to be fun to drive in the snow but without 4Wd its downright unsafe.
1989 Sahara. SOA, 35's, Locked.
Caboose89 is offline   Reply With Quote Quick reply to this message
Unread 11-14-2014, 01:51 AM   #2
Gausswave
To test the 4WD....( assuming your profile is correct and you have an open front diff )
Put the TC and transmission in neutral, set the parking brake and pull the cable lever to engage the 4WD collar on the front axle. Now jack up the front right ( passenger side ) tire. Spin the tire.
If the front drive shaft turns then you may have a bad T/C.
If it doesn't then pull the cover where the cable attaches and see why the collar hasn't shifted.
Gausswave is offline   Reply With Quote Quick reply to this message
Unread 11-14-2014, 06:36 AM   #3
fishadventure
Originally Posted by Caboose89
...but what do I need to look for? Could the shaft collar connecting the two shafts be seized up? Could the fork have broken in some way? Could it be because I am low on gear oil?...
Low on gear oil, no.
Fork may have broken but more likely the cable may have separated from the fork
If the cable handle moves but front axle is not engaging it is unlikely the collar is seized up.
You need to pull the cover and figure out what's happening or not happening. If collar and cable are all well functioning it is possible you have a broken axle. But you have to pull that cover and look first.
How many old threads actually convince *you* to read all 36 pages? http://www.jeepforum.com/forum/f12/length-envy-build-thread-629700/
fishadventure is offline   Reply With Quote Quick reply to this message
Unread 11-14-2014, 04:47 PM   #4
Caboose89
Figured it out. On my cable there is a button to unlock it, you then pull it out until it reaches a stop thanks to a spring, you then have to rock it forward to line up the splines and pull out the cable even more. The spring that was supposed to stop the cable on the first stop was not working, and I was pulling it out all the way without having to rock it to line up the front splines, causing them to not line up. So now I have to pull it out half the distance it would normally, rock it forward and it will then reach the second position on the cable after the splines line up. Took me a while to figure out and a lot of playing with the dang cable. Now I test to make sure the cable didn't go slack because of the faulty spring after it sits for a while by giving it a little gas and watching if the front turns. But that is manageable.
Unread 11-14-2014, 08:15 PM   #5
fishadventure
.ou then have to rock it forward to line up the splines and pull out the cable even more... up the front splines, causing them to not line up. So now I have to pull it out half the distance it would normally, rock it forward and it will then reach the second position on the cable after the splines line up...
That is a normal procedure glad you got it
Unread 11-14-2014, 08:22 PM   #6
Chrisnvegas
Chrisnvegas's Avatar
Glad I kept my original vacuum system.
What happens in my Jeep, stays in my Jeep
Chrisnvegas is offline   Reply With Quote Quick reply to this message
Unread 11-15-2014, 06:46 AM   #7
fishadventure
Yes, the stock vacuum system keeps pulling until it engages. Very seamless automatic and non-interactive.
The cable system works but one has to 'keep pulling' until it engages if the splines aren't aligned. Mine engages nicely when I am moving slightly but requires several seconds of attention to disengage.
Unread 11-15-2014, 08:01 AM   #8
Shadownwpa
Shadownwpa's Avatar
Glad I'm putting in tj shafts.
My build thread...
Shadownwpa is offline   Reply With Quote Quick reply to this message
Unread 11-15-2014, 10:10 AM   #9
fishadventure
It's one of those mind over matter things: if you don't mind it don't matter!
2WD lo was nice once again this morning backing a snowmobile trailer up a steep, curved, long driveway. One of the reasons that I don't mind. Cable does the same thing as the vac module just that the operator is aware of what it is actually doing. And to me that little bit doesn't matter.
