4wd not working - JeepForum.com
post #1 of 8 Old 10-30-2013, 07:12 AM Thread Starter
dechant91
4wd not working
I recently bought a 92 yj straight 6 with the np231 transfer case. I decided that it would be a good idea to go exploring a little one night and ended up snapping my slip yoke to the rear drive shaft in half. I tried throwing it in 4wd and nothing happened hopped out and looked to see what was going on and the front drive shaft would spin but wasnt catching inside the axle. Any ideas on what it may be? Any help on what it may be or how to fix it is greatly appreciated.
dechant91 is offline
post #2 of 8 Old 11-08-2013, 07:21 PM
psyco31
Not sure I got an 89 yj. Same issue. I out a posi lick cable on it and got rid of the vacuume switch. Front drive shaft turns. I looked in side it and it all looks good. Not sure. Hope u figure it out
psyco31 is offline
post #3 of 8 Old 11-08-2013, 07:22 PM
psyco31
Did u pull the did cover? What did it look like inside. Does the 92 have the split front like the 89s did?
psyco31 is offline
post #4 of 8 Old 11-09-2013, 04:44 AM
Mark05059
wranglers from the factory ar split axles... sounds like your cad is not working and left you stranded...there many threads on how to trouble shoot/fix it here on the forum.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 8 Old 11-09-2013, 07:17 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I should chime in on the three solutions for this problem and their pros and cons but I just wanted to note that I lost this thread when I moved it from the registry. OP may not be able to find it.
Luck Favours The Prepared
Anticanman is offline
post #6 of 8 Old 11-09-2013, 07:25 AM Thread Starter
dechant91
Ya I posted on another section in this forum and a couple ppl told me solution for making the cad basically a solid axle by eliminating the vaccum lines and moving the fork in the shift motor over and I'd be able to switch freely into 4wd
post #7 of 8 Old 11-09-2013, 07:28 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
http://www.jeepforum.com/forum/f12/t...80/?highlight=
Her ya go new guy. Read the thread linked inside the thread linked as well. And welcome to JF.
post #8 of 8 Old 11-09-2013, 08:47 AM
psyco31
I did this but I bought the posi lock cable actuator and installed that so I can pull it to turn on or turn it off. I am thinking about going to solid axles or a whole new axle set up in the future so I don't have to worry about this
psyco31 is offline
