-   -   4wd not working (http://www.jeepforum.com/forum/f12/4wd-not-working-1738754/)
dechant91 10-30-2013 07:12 AM
4wd not working
I recently bought a 92 yj straight 6 with the np231 transfer case. I decided that it would be a good idea to go exploring a little one night and ended up snapping my slip yoke to the rear drive shaft in half. I tried throwing it in 4wd and nothing happened hopped out and looked to see what was going on and the front drive shaft would spin but wasnt catching inside the axle. Any ideas on what it may be? Any help on what it may be or how to fix it is greatly appreciated.
psyco31 11-08-2013 07:21 PM
Not sure I got an 89 yj. Same issue. I out a posi lick cable on it and got rid of the vacuume switch. Front drive shaft turns. I looked in side it and it all looks good. Not sure. Hope u figure it out
psyco31 11-08-2013 07:22 PM
Did u pull the did cover? What did it look like inside. Does the 92 have the split front like the 89s did?
Mark05059 11-09-2013 04:44 AM
wranglers from the factory ar split axles... sounds like your cad is not working and left you stranded...there many threads on how to trouble shoot/fix it here on the forum.
Anticanman 11-09-2013 07:17 AM
I should chime in on the three solutions for this problem and their pros and cons but I just wanted to note that I lost this thread when I moved it from the registry. OP may not be able to find it.
dechant91 11-09-2013 07:25 AM
Ya I posted on another section in this forum and a couple ppl told me solution for making the cad basically a solid axle by eliminating the vaccum lines and moving the fork in the shift motor over and I'd be able to switch freely into 4wd
Anticanman 11-09-2013 07:28 AM
http://www.jeepforum.com/forum/f12/t...80/?highlight=
Her ya go new guy. Read the thread linked inside the thread linked as well. And welcome to JF.
psyco31 11-09-2013 08:47 AM
I did this but I bought the posi lock cable actuator and installed that so I can pull it to turn on or turn it off. I am thinking about going to solid axles or a whole new axle set up in the future so I don't have to worry about this
The time now is 12:44 PM.
