4wd not working - JeepForum.com
post #1 of 11 Old 12-15-2010, 04:54 PM Thread Starter
Svyse
4wd not working
Ok so when i put my jeep the guy i bought it from told me the 4wd wasnt working, but the only reason was beacuse of a rubber hose that rotted out. If some can help me with this i would appreciate it thanks
Svyse is offline
post #2 of 11 Old 12-15-2010, 06:22 PM
ALPHA-1
Put the jeep in neutral, Turn it on (just let it run for all of this) and Put in 4WD. LEAVE IN NEUTRAL!!!! But with 4wd selected instead of 2wd.There are two small hoses "about shoelace width" that go to the 4wd actuator under the passenger side. The actuator is bolted to the axle. . Pull the hoses off (may have to break the zip ties that hold the little hoses on) and see if one is sucking by holding your fingure over it. Make note which hose is sucking. Then put in 2WD (but still in neutral) and see if the OTHER hose is sucking. When in 2wd one should suck and in 4wd the other should suck. They alternate sucking lol. If you have suction from both (alternately) then your vacuum system is fine. The actuator might need to be replaced OR just free up the gunk keeping it from moving (that's what I did). Let me know how it works out. if you need help just message me. <---- Literally!
ALPHA-1 is offline
post #3 of 11 Old 12-15-2010, 06:41 PM
kloppk
The passenger side one sucks in 2WD and the drivers side one sucks in 4WD.
Vacuum diagram of the system.
kloppk is offline
post #4 of 11 Old 12-16-2010, 08:43 AM Thread Starter
Svyse
thanks for the help ill try that today and let you know how it works out
Svyse is offline
post #5 of 11 Old 12-17-2010, 02:07 PM
ALPHA-1
Did you figure it out yet? Is it the vacuum not working or something else (ie the actuator)
ALPHA-1 is offline
post #6 of 11 Old 12-17-2010, 02:40 PM
JDNightFox
I need to get my 4WD fixed... the shift fork won't engage and there's absolutely no suction from anywhere
JDNightFox is offline
post #7 of 11 Old 12-17-2010, 03:41 PM Thread Starter
Svyse
i tried all that i have suction on 2wd but my transfer case isnt letting me put it in 4wd to try it out...so i dont know if i need to drop my transfer case and pull it apart or what
Svyse is offline
post #8 of 11 Old 12-17-2010, 03:49 PM
Brown6041
i have a brand new vacuum harness i will sell you it is in the box still
Brown6041 is offline
post #9 of 11 Old 12-17-2010, 05:26 PM Thread Starter
Svyse
i dont know if its the actually vacuum though the shifter wont let me engage it in 4wd do the hoses need to be put back on before i engage it in 4wd
Svyse is offline
post #10 of 11 Old 12-18-2010, 07:16 AM
GreenRenegade
Not sure exactly why it's not letting you move the selector. Are you auto or 5 speed? It may not move if you are in Park (not sure, haven't tried). If that isn't the case, look under the frame and see if the lever or mechanism is catching on something or if the linkage is catching somewhere. If you don't see anything, you may have to take off the floor cover and take a peek from the top. It could be something as simple as a small stone lodged in there somewhere.
If all looks good and still wont move, disconnect the linkage and see if it moves then. If it doesn't move, you need to take a closer look and see where it's catching at or if it's completely rusted stiff. If it moves, it's not the shifter (obviously, huh?).
Anyways, follow the linkage with your fingers and a flashlight and see where that bugger is catching. Hopefully you find where it might be binding or bent and you'll be able to fix it. If not, it has to be in the t-case. That's where I have to let you make your own decisions as I have never snooped at the internals of a t-case.
Dan
2013 Wrangler Rubicon 2dr
GreenRenegade is offline
post #11 of 11 Old 12-18-2010, 09:08 AM Thread Starter
Svyse
thanks for all the help...when i get time this week i'll give it a closer look and let you know what i found
Svyse is offline
Blinkers quit working, please help me get them working again. fishmanwill YJ Wrangler Technical Forum 7 01-02-2010 06:46 PM
Not working 4hi but working in 4lo Ej132 YJ Wrangler Technical Forum 11 12-19-2009 11:00 AM
uconnect stopped working after 10 minutes of working archlich JK Wrangler Technical Forum 2 09-03-2009 06:57 PM
ARB Locker working in cold weather. Compressor keep turned on, but not working hard Sparty TJ Wrangler Technical Forum 3 02-01-2009 05:31 PM
A/C not working in a '98 SE banterer TJ Wrangler Technical Forum 4 11-20-2005 08:13 PM
