4wd noises - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4wd noises
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiWarn, Smitybilt, Engo, Rugged Ridge Winches at CCORIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-14-2012, 10:11 AM   #1
ErikPeterson
4wd noises
I searched and really couldn't find my problem. When in 4wd, my jeep has started making two new noises. At first I thought it might be a linkage problem but it isn't. I checked that. And the four wheel drive does engage both high and low. The first noise starts in 2nd gear and sounds like a vacum. As rpm's increase, the pitch gets higher. The second sounds not like a grind but like a "brushing" or "rubbing". Any ideas? Thank you in advance.
ErikPeterson is offline   Reply With Quote Quick reply to this message
Unread 01-14-2012, 11:13 AM   #2
Tcrouch22
I have the same vacuum sound when I use 4wd too. I can't figure our what it is
Tcrouch22 is offline   Reply With Quote Quick reply to this message
Unread 01-14-2012, 11:23 AM   #3
ErikPeterson
Maybe a leak?
1990 Wrangler YJ "Linda"-Project
2012 Patriot Sport FD1 "Beth"-DD
Unread 01-15-2012, 09:03 AM   #4
ErikPeterson
Bump
4wd , noise , rubbing , vacuum , YJ
