4wd LOW is a no go???? - JeepForum.com
post #1 of 9 Old 10-13-2011, 07:31 PM Thread Starter
misfit650
Hey guys.
I got a 95 yj 6 cy auto and it wont budge into 4wd LOW.
It shifts into 4wd hi n the N with ease but wont budge into low
I dunno whats wrong? Any help would be appreciated.
Thanks!
misfit650 is offline
post #2 of 9 Old 10-13-2011, 07:33 PM
07lane40
let your foot off the brake? there can be some major binding and some tcases are finicky.
07lane40 is offline
post #3 of 9 Old 10-13-2011, 07:34 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
If you're shifting while rolling, and it still won't go into 4LO, try adjusting the linkage.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #4 of 9 Old 10-13-2011, 07:36 PM
moonshinefuel
Maybe the shift lever is hitting the tub.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #5 of 9 Old 10-13-2011, 08:01 PM Thread Starter
misfit650
Its a new to me jeep.. so im new to this... I put it in N and rolled n it wouldnt budge into low...i didnt know how hard i should pull on it?
post #6 of 9 Old 10-13-2011, 08:30 PM
Old4X
1990 CJ7
4 LO is back - right - and back again. Are you pushing the shifter to the right before you try to pull it back again for 4 LO ?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #7 of 9 Old 10-13-2011, 10:09 PM
bharris68
Daily Driver
Any body lift on the Jeep such that the shift lever is, as noted, hitting the tub before you can pull far enough into 4Low?
if not - check under the jeep and make sure that the linkages are not full of crud and or pins/springs/retaining bolts are not rusted/missing/sheared off
bharris68 is offline
post #8 of 9 Old 10-14-2011, 06:21 AM Thread Starter
misfit650
Yes i am shifting correctly...ill check under her today...is there a skid plate obstructing a view of the links?
I believe its close to stock-ill have to check
post #9 of 9 Old 10-14-2011, 11:04 AM
07lane40
what started for me as checking shifter linkage ended up in me rebuilding my t-case... its not too hard, but good luck
07lane40 is offline
