4WD light indicator - JeepForum.com
post #1 of 6 Old 07-12-2013, 09:21 AM Thread Starter
wildbadbill
4WD light indicator
so,I can feel getting into 4WD ,but the light doesn't come on (used to).
When I jump the wires by the axle,it does come on.So,I'm thinking that the activation switch is bad/stuck/
Anything to be aware of before I unscrew it?
Thanks.
wildbadbill is offline
post #2 of 6 Old 07-12-2013, 09:37 AM
SeanB95YJ
could be the vacuum actuator itself is kaput too... common occurrence, in which case you're not really in 4wd at that point, even though your T-case says otherwise
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 6 Old 07-12-2013, 09:46 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
This. But no, you shouldn't have any problems from just unscrewing it.
Michaelgoesrawr is offline
post #4 of 6 Old 07-12-2013, 09:56 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Here's an option
http://www.jeepforum.com/forum/f12/t...80/?highlight=
Luck Favours The Prepared
Anticanman is offline
post #5 of 6 Old 07-12-2013, 10:43 AM Thread Starter
wildbadbill
thanks guys.
post #6 of 6 Old 07-12-2013, 12:06 PM
UZI4U
If it's just the switch, I did this for mine: http://www.jeepforum.com/forum/f12/4...te-up-1276663/
MCLMM
UZI4U is offline
