4wd Light ? - JeepForum.com
post #1 of 2 Old 02-28-2002, 04:29 PM Thread Starter
RCHavok797
RCHavok797's Avatar
4wd Light ?
Over the past month my 4wd light has stopped working. The 4wd is still working fine just not the light. If I give it some gas the light goes on but only for a short time. Correct me if I'm wrong, but doesn't the light operate by a vaccum? Is it just a vacuum leak? Its obviously not anything serious just something that annoys me.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #2 of 2 Old 02-28-2002, 05:53 PM
bobznew
If I'm not mistaken, the switch that sends the signal to the light panel is located just above the vacuum actuator on the right side of the front axle. I think this is right, b/c I replaced this switch when I installed a posi-lok.
But think, it could be much worse. The light could work just fine, but the 4wd could be broken! This was a problem that I recently had with my YJ.
'97 ZJ, 4.0L, Gibson Cat-back system, Daily Driver
'95 YJ, 4.0L, 3.5" BDS suspension lift, Boomerang Shackles, BDS Shocks, 33x12.50 TSL's, Lock-Rite in rear, No-Slip up front, Posi-lok, Warn XD9000i winch, and a ton of dried Mississippi mud!
bobznew is offline
keep blowing tail light, turning singnals and interrior light fueses on my TJ bigtime13 TJ Wrangler Technical Forum 1 11-06-2009 07:34 PM
Interior light issues - dome light and wiring mess liminalhigh YJ Wrangler Technical Forum 0 07-20-2009 08:47 AM
Light Braket / Off-Road Light Install - Complete redrom01 JK Wrangler Technical Forum 11 03-29-2009 01:38 PM
Turn signal dash light stuck on, warning chime, no shift light. bmlawless TJ Wrangler Technical Forum 7 10-21-2008 09:29 AM
brake light/Hazard light fuse blows as soon as you install it! jeffro123 YJ Wrangler Technical Forum 6 08-23-2005 11:57 AM
