4wd indicator light dana 30 conversion - JeepForum.com
post #1 of 25 Old 11-02-2013, 08:39 PM Thread Starter
Springer45
So I converted my dana 30 to a solid axle (the cheap spring in housing way). The problem I'm having now is I can't get the 4wd indicator to work. I spliced on a new connector and put a 97 wrangler sensor in the np231 transfer case. It worked like three times then stopped. While it worked it was unpredictable at best. So I disconnected the connector and made a jumper to make sure my soldered connections were good... Light came on. But when I put it back together, nothing. The switch that was recommended (dorman brand) from the 97 had a short looking button compared to the stock pneumatic switch (is that normal?). So that being said my questions are, could there be something in the transfer case that is warn that could prevent the button from being pushed? Has anyone else done this conversion successfully? Is the 97 np231 any different in regards to the switch? Please I'd like to hear from people that have successfully done this. Ps the pneumatic system was also iffy and when I added my lift kit with the skid plate spacer it went from iffy to nothing. Could the lift be causing my problems?
Springer45 is offline
post #2 of 25 Old 11-02-2013, 09:33 PM
YJ4LIFE
oops
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #3 of 25 Old 11-02-2013, 11:41 PM Thread Starter
Springer45
Uh... Not exactly the response I was looking for. I don't think the lift caused the problem. It seemed to have similar problems before I put the lift on. Idk how the inside of the np231 t-case works but I can imagine that there could be some parts that could wear and cause these issues?
post #4 of 25 Old 11-03-2013, 12:53 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Try a little dielectric grease.
Luck Favours The Prepared
Anticanman is offline
post #5 of 25 Old 11-03-2013, 06:18 AM
Old4X
1990 CJ7
If you have solid axle D30, there is no need for a light. If you want a light to tell you you have shifted the transfer case lever to 4 Hi or 4 Lo, just get a vac switch like used on the 88 - 90 YJs, and hook up the output from the transfer case vac switch directly to the light switch.
Really, the only reason for the dash light was to inform on if the front axle is locked or not.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #6 of 25 Old 11-03-2013, 06:35 AM
fishadventure
I have always wondered why people get concerned with 4WD lights. Whenever any of my 4x4s weren't engaged when I threw the transfer case lever it was pretty obvious that it wasn't "in"...
Shackles and D-rings: different things!
Cranking IS turning over
fishadventure is offline
post #7 of 25 Old 11-03-2013, 08:45 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
People like them. I like my lights. Just how it is.
Michaelgoesrawr is offline
post #8 of 25 Old 11-03-2013, 09:57 AM
Old4X
1990 CJ7
And to me an electrical system and battery is optional equipment. Give me a magneto based ignition and get out of my way.
Old4X is offline
post #9 of 25 Old 11-03-2013, 10:35 AM Thread Starter
Springer45
The reason I want the light working is to keep the jeep as original as possible. It makes me feel good, what can I say. As for the pneumatic switch in the 87-90 wranglers, it last the same as the 91-95. The problem is the pneumatics that control the locking axle are a flaw IMO and I need a reliable jeep. The solid axle in the front end is the way to go but I want my indicator to work.
post #10 of 25 Old 11-03-2013, 10:42 AM Thread Starter
Springer45
Not a bad suggestion. My concern is that it will just arc itself to death. If it doesn't have a good connection before the dielectric grease it won't have the kind of connection that doesn't arc. I appreciate the suggestion though.
post #11 of 25 Old 11-03-2013, 11:00 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
The light is useless. IMO if you need a light to tell you that you are in 4wd and can not tell by the position of the 4wd lever you are an idiot. Hell you even tell by how the vehicle handles wether its in 2wd or 4wd
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #12 of 25 Old 11-03-2013, 11:43 AM
jamnjeep
Not sure about the TJ switch. When I did my TJ shaft conversion I went to the pull a part and pulled a couple switches out of mid 90s XJs with the 231 TC, along with the connector. Cut my stock connector off and spliced in the XJ connector. My 4x4 light has worked fine. The XJ switch was also shorter than the YJ switch but did not have any effect on 4x4 light. Could be a bad switch or short in the wiring if it works intermittently .
1994 YJ under construction....
jamnjeep is online now
post #13 of 25 Old 11-03-2013, 12:11 PM Thread Starter
Springer45
Guess you didn't read the post. I like the original things to work. Things like the indicator. You're right it's easy to tell if the vehicle I'd in 4wd, but thus time around I bought an automatic so my wife can drive it and it's a good idea for people like her to have it working. She CANT tell its in 4wd. Not saying it is just for her as I said I like things to be as original as possible. My jeep is rare (93 w/ auto trans and air conditioning stock) and I'd like to keep things original
post #14 of 25 Old 11-03-2013, 12:14 PM Thread Starter
Springer45
Thanks for the reply. It's good to hear that the switches are shorter right from the factory. Maybe I'll have to have someone shift the t-case while I go a continuity test. Hopefully it's just a bad switch.
post #15 of 25 Old 11-03-2013, 12:16 PM Thread Starter
Springer45
Anyone know enough about these transfer cases to know if there is an internal part that could be warn and causing problems?
