4wd indicator - JeepForum.com
post #1 of 7 Old 09-16-2011, 04:08 PM Thread Starter
lah2420
4wd indicator
95 4cyl 5speed. No light comes on when put in 4wd. Thinking burned out bulb, I pulled the bezel over the steering wheel to check the bulb. There is no place for a 4wd indicator on the bezel. Turn signals, shift indicator, ABS, Check Engine, Brights, and One green looking symbol that I didn't recognize doesn't even have a socket for a bulb under it. My 87 had an indicator within that bezel. Did they decide to do without in 95?
lah2420 is offline
post #2 of 7 Old 09-16-2011, 04:26 PM
Louie4
Rickety Wrecked Son!
Louie4's Avatar
Yours should be on the bezel above the radio on the far left. That's where mine is at least. You might want to take the switch out of the front axle and see if it turns the bulb on and off.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline
post #3 of 7 Old 09-16-2011, 05:10 PM Thread Starter
lah2420
If it's a red LED right under the temp gauge, the switch won't matter until I find where one of the previous owners hid the wires they cut.
lah2420 is offline
post #4 of 7 Old 09-16-2011, 05:52 PM
Louie4
Louie4's Avatar
I'm not sure what light you're talking about but anyway I got this pic off JF. It's small but it shows where the 4wd light is on my jeep.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Louie4 is offline
post #5 of 7 Old 09-16-2011, 06:06 PM Thread Starter
lah2420
I'll take a look there. I think that's where the clock was on my 87. I didn't think about them putting the 4wd indicator there. The LED I'm talking about is probably some aftermarket thing one of the POs put in there. Thanks.
lah2420 is offline
post #6 of 7 Old 09-17-2011, 01:25 AM
ss454
Mine's the opposite, it won't turn off
ss454 is offline
post #7 of 7 Old 09-17-2011, 03:51 AM
Louie4
Louie4's Avatar
I had that problem too years ago. My shift motor was stuck in the locked position so I took it off and cleaned it up with brake cleaner, stuck it back on and it's worked fine for years.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Louie4 is offline
4wd indicator wanabejeeper YJ Wrangler Technical Forum 11 03-23-2010 05:17 PM
4WD Indicator lilngineer TJ Wrangler Technical Forum 7 12-15-2007 09:53 AM
4WD Indicator Cobra001 TJ Wrangler Technical Forum 14 04-16-2007 08:08 AM
4WD indicator tomcat87 YJ Wrangler Technical Forum 7 12-05-2003 08:30 PM
4wd indicator migliori YJ Wrangler Technical Forum 9 08-19-2003 03:24 PM
