4wd cable swap - JeepForum.com
post #1 of 12 Old 04-23-2013, 03:41 PM Thread Starter
LAyj
4wd cable swap
Swapping my 4wd to cable activation rather than vacuum! Good idea or no?
LAyj is offline
post #2 of 12 Old 04-23-2013, 03:54 PM
msprooch
We need more information on your needs/future plans/current set up
msprooch is offline
post #3 of 12 Old 04-23-2013, 03:56 PM
jbolty
jbolty's Avatar
No harm, but why? Is the vacuum system broken?
jbolty is offline
post #4 of 12 Old 04-23-2013, 03:59 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I would pass
http://www.jeepforum.com/forum/f12/t...80/?highlight=
Luck Favours The Prepared
Anticanman is offline
post #5 of 12 Old 04-23-2013, 03:59 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
I have it on my Jeep. However, if you buy the posi-lok kit, you will need to plan ahead for lift height because there are two different cable lengths. It works fine and I have no complaints but so far my Jeep has not been beaten on with the kit on.
Michaelgoesrawr is offline
post #6 of 12 Old 04-23-2013, 04:26 PM
tweb14
I have it, it's somewhat cheap but you could just reverse the fork and it'll always work anyway. If you're not in 4wd you wont realize its locked anyway so I just leave mine pulled anyway.
Plus it's a ***** to route. It's not as flexible as I imagined it would be
tweb14 is offline
post #7 of 12 Old 04-23-2013, 05:25 PM Thread Starter
LAyj
Yes vacuum system is broke. It currently has BFG A/T 33s with 3in body lift. I bought it with both on like that. I'm planning on 4 in rough country lift, bumper, winch, lockers eventually. Should I keep the body lift when I put on the 4in suspension lift or take it off
LAyj is offline
post #8 of 12 Old 04-23-2013, 05:30 PM Thread Starter
LAyj
And there isn't much places to rock crawl around here so I'm mostly gunna be going thru water/mud/trails/muddy trails
LAyj is offline
post #9 of 12 Old 04-23-2013, 05:34 PM
jserna
1987 YJ Wrangler
I have the Posi-lock on my 87 and I like it alot.
jserna is offline
post #10 of 12 Old 04-23-2013, 05:41 PM
Mark05059
skip the rough country and get another mfg of lift springs.. they all sag but rough country just doesnt hold up at all.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #11 of 12 Old 04-23-2013, 05:47 PM
tweb14
He's right. The 6" springs are the only 'heavier duty' ones but if I was gonna do it again I'd say bds or ...anything else
tweb14 is offline
post #12 of 12 Old 04-23-2013, 07:19 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
The vacuum system is fine. Just fix it. It's not rocket science.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
