4wd after new carb and nutter - JeepForum.com
post #1 of 7 Old 05-13-2010, 06:58 PM Thread Starter
blackangus86
I am sure this has been answered many times. Searched and could not find anything right away. Installed a motorcraft carb. Where do i attach the red vacuum hose too? Mine goes into globe looking thing under battery tray
blackangus86 is offline
post #2 of 7 Old 05-13-2010, 09:23 PM
wanabejeeper
1987 YJ Wrangler
for starters fill out your profile.... what year jeep do you have?
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #3 of 7 Old 05-13-2010, 11:17 PM
dtn8tr
Hook the red line up to manifold vacuum...such as a tee coming off under the vac line to the brake booster from the manifold.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #4 of 7 Old 05-14-2010, 05:46 AM Thread Starter
blackangus86
thanks for the help its an 87 would a port on the carb work? also if i remove the actuatorwith another person shifting from 2wd to 4wd should I be able to see the fork move?
post #5 of 7 Old 05-14-2010, 06:28 AM
squib518
I did what dtn8tr suggests and got manifold vac off of the brake booster tee. I routed straight from the tee over to the red line--I had nothing going to the "globe" under the battery tray. I plugged all the lines coming out of the globe.
You won't be able to see the fork move. You can get all four tires off the ground and test 4X4, but the better way is to get in a parking lot and and turn a tight circle--once out of 4x4 and once in 4x4. You'll know quickly whether it is working or not.
squib518 is offline
post #6 of 7 Old 05-14-2010, 09:39 AM
dtn8tr
Yeah...I just nuttered mine and installed a Weber recently and was cleaning up vac llines and inadvertently moved my line and didn't have 4wd. I put it up on stands to verify because I could feel the tc shift into 4wd. I traced back the line and found that I had put it on ported vac and it wasn't locking in...moved it and all was fine.
dtn8tr is offline
post #7 of 7 Old 05-16-2010, 07:07 PM Thread Starter
blackangus86
okay. if i disconnect at the front axle actuator i can feel vacuum at green in 2wd and if i hold my finger over the black one i have vacuum at yellow in 4wd. How much vaccuum should i have? my 4wd light ups on the dash, but it is still not engaging.
New Carb nutter question blackangus86 YJ Wrangler Technical Forum 0 08-08-2009 06:59 AM
Post nutter, now what carb.? tet-ness-shot YJ Wrangler Technical Forum 1 07-30-2009 08:26 PM
Nutter Question And Carb... bcameron1974 YJ Wrangler Technical Forum 1 12-25-2008 10:40 AM
Anyone done the nutter with stock carb? bidderking YJ Wrangler Technical Forum 7 11-04-2008 10:42 AM
Nutter and Carb NJscott YJ Wrangler Technical Forum 4 12-07-2007 09:42 AM
