4wd 4H works but not 4L - JeepForum.com
post #1 of 6 Old 06-20-2006, 09:48 PM Thread Starter
Jakesteads
Worked 1 week ago since then i have put on 1" body lift and 1.25" shackles and didn't do a t-case drop..... did this cause it maybe?
Jakesteads is offline
post #2 of 6 Old 06-20-2006, 10:10 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Are you just getting into t-case neutral, or does it shift all the way to 4-lo? If you only reach neutral, you might need to adjust the boot and cut the tranny-cover an extra inch or 2 to allow for proper movement.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #3 of 6 Old 06-21-2006, 08:30 AM Thread Starter
Jakesteads
when i get it down to 4WL it does not engage and it "stays in neutral" even if im in gear.
post #4 of 6 Old 06-21-2006, 08:36 AM
COSourdough
Adjust the linkage. Not too complicated a process. No guarantee, but sounds like that might be the problem.
COSourdough is offline
post #5 of 6 Old 06-21-2006, 09:05 AM Thread Starter
Jakesteads
hmmm ill give that a try
post #6 of 6 Old 06-21-2006, 09:22 AM
King03Kev
King03Kev's Avatar
1987 YJ Wrangler
Hey, I had same proplem after 1" BL install, You will need to trim around transfer case shifter at the back of boot around floor sheetmetal, 1" or so you won't have any more problem. Good luck.
kevyj87 '87 I6 5spd, 215,000+ miles, Herced, Nuttered, Weber, HEI, RE 4", 1" BL, 4:11's, np231, 33x12.5's, SYE & shaft, 1" brown dog mm, home made bumpers front & rear, Ramsey 8,000lb winch
King03Kev is offline
what works best? gamble3527 TJ Wrangler Technical Forum 3 09-23-2009 02:18 PM
what works with what? Hillbilly Jeep YJ Wrangler Technical Forum 0 04-11-2008 10:28 PM
This works (for now) 1BadJeepX06 TJ Wrangler Technical Forum 3 05-29-2006 10:38 PM
Fan works on 1,2 and 4. Not 3 shaggyd TJ Wrangler Technical Forum 5 11-11-2005 09:17 PM
No 4Lo - but 4Hi works? el guapo YJ Wrangler Technical Forum 4 01-25-2005 08:43 AM
