4th slave....this year - JeepForum.com
post #1 of 15 Old 08-15-2011, 02:14 PM Thread Starter
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I am leaking again. Any thoughts? new master..... but 4 slaves? WTF? The last one I paid a shop to install because I was so mad.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #2 of 15 Old 08-15-2011, 04:30 PM
scifone
Learns the hard way
scifone's Avatar
What brand are you buying?
scifone is offline
post #3 of 15 Old 08-15-2011, 06:46 PM Thread Starter
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Napa or what ever they sell and car quest.
Where can I find id numbers on my trans. I have doubts its a 91 like the frame and tub are.
Poke is offline
post #4 of 15 Old 08-15-2011, 08:46 PM
johnny27030
Do you have any type of performance clutch package? Heavy duty pressure plate? May just be the slaves are on the shelf to long and the seals inside them are crap. Ide try another brand from another supplier.
johnny27030 is offline
post #5 of 15 Old 08-16-2011, 06:22 AM Thread Starter
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
neither....
but you know the two hard lines coming out of it? Well all 3 times I got slaves the metal hard lines that come with them in the box are bent wrong. They are not bent right to go to the hole in the bell housing. Its like there are supposed to be 2 holes in my bell housing or NAPA has the wrong part So the first 2 times I just used my old hardlines, the 3rd time when I let a firestone shop do it... they told me they had the same issue and used the old hardlines.
maybe my AX-15 is from something else? or its not an AX-15 but similar? not sure what it is. Perhaps when you use the old hardlines they dont seal because the new slaves have a slightly different design?
this is what I am leaning towards
Poke is offline
post #6 of 15 Old 08-16-2011, 10:36 AM
dancytron
Switch it over to an external slave (search, there are lots of threads). Then when it fails at least it is a much smaller problem.
dancytron is offline
post #7 of 15 Old 08-16-2011, 12:06 PM
TheNewbie
^^^ This.
I'd be pissed if I had to pull my tranny 4 times in a year.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #8 of 15 Old 08-16-2011, 12:31 PM Thread Starter
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I just finished my jeep envy project and this pops up on the shake down run
Poke is offline
post #9 of 15 Old 08-16-2011, 01:15 PM
zeus87gn
1987 YJ Wrangler
If you decide to stay with the internal slave, make sure the lines are bent correctly and you don't have to remove them for any reason. I have been told by an experienced Jeep builder that if you ever have to remove the metal lines, they will leak.
Buy one with the correctly bent lines - the bleeder tube on top, the pressure tube on bottom - and they should both be shaped to fit through the opening in your bellhousing. If they aren't right, it's not the right part.
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #10 of 15 Old 08-16-2011, 01:21 PM Thread Starter
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I wonder what my chances of stopping that leak are
Poke is offline
post #11 of 15 Old 08-16-2011, 01:43 PM
No-Doors
According to the FSM for a 93 wrangler; the hydraulic lines should never be disconnected except at the quick disconnect fitting. I have attached a link to the online fsm. Hope this helps.
http://www.jeep4x4center.com/knowled...ex.htm#service
A Rancher told me that back home he can drive his Jeep all day and not get off his own property; I said "I've got a Jeep like that too"!
"Nothing sucks more than that moment during an argument when you realize you're wrong" (Paul :-)
No-Doors is offline
post #12 of 15 Old 08-16-2011, 03:57 PM
zeus87gn
1987 YJ Wrangler
With the slave still in the housing? 0%
I'd have to call him to find out if there is any other solution than buying the right cylinder.
I can do that if you like.
zeus87gn is offline
post #13 of 15 Old 08-16-2011, 07:23 PM
4.7stroker
Start gathering the parts and convert it to an external slave.
The definition of madness is doing the same thing over and over expecting a different result.
Albert Einstein
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #14 of 15 Old 08-16-2011, 07:32 PM Thread Starter
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Anyone make a kit? I would rather pay than piece it together.
Poke is offline
post #15 of 15 Old 08-16-2011, 09:29 PM
4.7stroker
Not that I am aware of, keep an eye on ebay for the bell housing, the other stuff can be bought new.
Dwayne
[url]
[url]
Ax15+ What year do I have? slave cylinders are different. BigDeaner YJ Wrangler Technical Forum 22 08-05-2009 02:19 PM
Internal slave to external slave conversion on puegout trans. zippome YJ Wrangler Technical Forum 11 04-20-2009 10:26 AM
Master, Slave, and Clutch Repaired 2 time under a year Urb4nTr0ll YJ Wrangler Technical Forum 0 12-16-2008 03:39 PM
master slave cyl. to slave clutch hose gfortier YJ Wrangler Technical Forum 0 09-16-2008 07:37 AM
What year did they switch to external slave? supraman1990 YJ Wrangler Technical Forum 8 06-30-2007 08:25 AM
