4th gear idel issues - JeepForum.com
post #1 of 6 Old 05-29-2010, 07:07 PM Thread Starter
kiitanak
so ive noticed for the past couple of weeks this new problem, or maybe just a small issue. i live on the top of a mountain(5min just to get to the bottom) and when im driving down the hil, switching sometimes from 4th gear into N, too slow down. the idel on my RPM gauge jumps all the way to zero, and sometimes my yj just shuts off, or instead of shutting off, it bounce back up to normal....
is this a common problem on a yj. i have 255,000 miles on it, runs great, still strong. except for that issues when im driving and i give it N, when coming off 4th. it also happens sometimes on the hwy, if im on 4th and then put it in N to just cruise on a down hill of a hwy.
help plz!!!
thnks again guys,
p.s. car is completey stock, no mods no where.
kiitanak is offline
post #2 of 6 Old 05-29-2010, 08:09 PM
moonshinefuel
Maybe you just need a tune up, and clean out your throttle body system, put some good quality fuel injector cleaner oin the gas. Eliminate all the common causes first.
moonshinefuel is offline
post #3 of 6 Old 05-29-2010, 09:36 PM Thread Starter
kiitanak
thnxs will be checking that out this weekend
kiitanak is offline
post #4 of 6 Old 05-29-2010, 09:52 PM
MJMPC
Try checking for codes.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 6 Old 05-30-2010, 04:46 PM Thread Starter
kiitanak
thnxs
kiitanak is offline
post #6 of 6 Old 06-02-2010, 09:02 PM Thread Starter
kiitanak
found oil spewing out of the crank case vent hole, it has a connection to the airbox, the tb was sucking that up, any idea hoe i can fix that, has this happened to anyone????
kiitanak is offline
i need some HELP on gear issues Russmister26 TJ Wrangler Technical Forum 11 09-03-2009 02:14 AM
idel or idleing rough yjjustforme YJ Wrangler Technical Forum 3 02-11-2009 07:31 PM
Yj wont idel Jawjaboy YJ Wrangler Technical Forum 3 02-05-2008 06:36 PM
High idel after taking on water killas1mo TJ Wrangler Technical Forum 7 07-18-2006 10:57 PM
2nd gear issues jeepjeepgrl TJ Wrangler Technical Forum 5 08-01-2003 03:55 PM
