4th and 5th gear bad vibrations, ideas? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4th and 5th gear bad vibrations, ideas?
All Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 04-26-2010, 11:40 PM   #1
p3c0r
So I was on my way home from work tonight and hopped on the freeway I put it in forth and noticed a little vibration, popped it in 5th and it was shakin the whole jeep.
Now it is dark and raining here so I didn't feel like gettin' under there with a flashlight tonight, but any clue to what it is?
Edit::I have a 1995 Jeep Wrangler 5spd with the 4.0l, everything is stock minus a 4in lift
edit::Problem has been fixed, this thread may be deleted
p3c0r is offline   Reply With Quote Quick reply to this message
Unread 04-27-2010, 12:22 AM   #2
MJMPC
Need to fill out your jeep info a little more so we can help.
MIKE
http://www.dav.org/
MJM Powder Coating
Elizabethtown Ky.
http://www.cityprofile.com/
MJMPC is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 05:41 AM   #3
kdiacont2010
what ended up being your problem?? im having the same issue
My Jeeps:
93 YJ - 4 Angry Squirrels, 5 Speed, 3in Body Lift, 33x10.50s
06 WK Limited - No Mods Yet
kdiacont2010 is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 06:11 AM   #4
scubamc
If the OP didn't update this thread two years ago I don't think he's going to do it today.
Check your u-joints, trans mount, motor mounts and balljoints.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 06:12 AM   #5
kdiacont2010
Thanks... I didn't even look at the date. It was just at the top when I did my search.
My Jeeps:
Unread 04-06-2012, 03:42 PM   #6
p3c0r
Well it's a combination of the lift and a bad or worn u joint. Need to get a slip yoke eliminator kit and a cv driveshaft to get rid of the vibration all together
Unread 04-06-2012, 05:29 PM   #7
scubamc
So in two years you haven't fixed the problem. Nice
