4Point Harness mounting - JeepForum.com
post #1 of 6 Old 10-28-2014, 12:16 AM Thread Starter
YjJoel
I have a 92 yj and 2 4point bolt in harness from Corbeau and i was wondering if i can mount the the two lap ones where the clicker for the belt and the seat belt bottom bolt is then bolt the the top two the roll bar above.
Would that become fatal.
YjJoel is offline
post #2 of 6 Old 10-28-2014, 06:04 AM
Mike Romain
Don't think they will reach. You are aware that 4 point belts aren't street legal right? Folks put them in for off road with custom roll bars and keep the street legal 3 point set for on road.
Mike
Mike Romain is offline
post #3 of 6 Old 10-28-2014, 12:32 PM Thread Starter
YjJoel
Yes I do know that I was just seeing if that would work until I got my new seats and bar
YjJoel is offline
post #4 of 6 Old 10-28-2014, 12:59 PM
Norcal_chris
Norcal_chris's Avatar
Use your stock belts untill you can run a proper harness bar and put them in the right spots.
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #5 of 6 Old 10-28-2014, 01:12 PM
TSEJEEPERS
Read this
http://www.pirate4x4.com/tech/billav...rness_install/
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #6 of 6 Old 10-28-2014, 09:12 PM
jason m
Nothing but the facts
jason m's Avatar
This, seen to many 4 and 5 point harnesses installed wrong, your talking about your spline if installed wrong or some type of serious back pain even in a small roll or hit.
Run them right or don't run them at all.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
4 point harness , harness , mounting issue
