4in suspension lift + 2in shackles + 2in body lift = 35in tires? - JeepForum.com
post #1 of 25 Old 03-20-2009, 12:08 AM Thread Starter
snou52
hey everybody,
quick question i purchased a 94 wrangler which has a 4" suspension lift, 2" shackle lift, and 4" body lift and it currently has 35in tires...whenever i go wheeling the tires do rub a bit during extreme flex...my question is can i drop it down to a 2" body lift and still have enough tire clearance for my 35's? i'm hoping the 2in drop will help with my jeep being a bit top heavy and i want to tighten up my steering a bit....thanks in advance for any input.
snou52 is offline
post #2 of 25 Old 03-20-2009, 12:13 AM
Toms87
1987 YJ Wrangler
ten inches of lift??? or 8? I have 5 inches and 33s and am installing TJ flares which should be more than enough room for decent flex. I'd say go to TJ flares if you don't already have them, and you should be able to get rid of the body lift, or drop it down to 1 or 2.
Toms87 is offline
post #3 of 25 Old 03-20-2009, 11:01 AM
titoheadfaceman
Holy cow! A 4 inch body lift?? I thought my 2 inch was bad! But to answer the question, if your tires are hitting with the way it is now, then they will hit even worse when you lose the 2 inches. I agree with Toms87. Get you some TJ flares or some other type and cut away the extra fender. That would be the best way I would think and help you get rid of that 4 inch body lift!
titoheadfaceman is offline
post #4 of 25 Old 03-20-2009, 11:58 AM
TheRealOldjeep
Picture please
Chuck P
94 YJ 2.5L/AW4 (Gone)
98 ZJ Limited 5.2 - sons car
97 TJ 2.5L/30RH - daughters car
My site
TheRealOldjeep is offline
post #5 of 25 Old 03-20-2009, 12:01 PM
MAX_Xj
MAX_Xj's Avatar
^^^ X2 on the pictures
1998 4dr XJ
MAX_Xj is offline
post #6 of 25 Old 03-20-2009, 12:56 PM
sprowley
The kind of trouble you'd be in with 4" body lift and 2" shackle lift if you ever actually did something where you *needed* 35" tires.... is staggering.
I was going to say you should drop the shackle lift and get some sensible shackles... but if its really a 4" body lift (i've never even SEEN that) then that should go first. If you want the height a SOA + 2.5" lift will flex soo much better, ride, better, and won't KILL YOU on the road or trail
92 YJ Islander Sold!
97 TJ Sport black on black with MT/R Kevlars and lots of new parts coming!
Canon EOS-1D Mark III, Canon EF 70-200mm f/2.8L USM, Canon EF 17-35/2.8L USM, Sigma 50mm f/2.8 EX USM
sprowley is offline
post #7 of 25 Old 03-20-2009, 01:09 PM
MLJeeper
MLJeeper's Avatar
I would also question the quality and or condition of your 4" springs. I run a 3.5" lift, 5/8" lift shackles, 2" bl and TJ flares with gratuitous cutting and i clear 35s.
Im with the others, i wanna see pics of the 4" bl. I have seen these on some old pickups but never a jeep.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #8 of 25 Old 03-20-2009, 02:49 PM
brinoff
brinoff's Avatar
I really want to see this.
93YJ 4.0 I6, AX-15, NP231 Teraflex SYE, Tom Wood Drive Shaft, G2 D44 ARB, ARB locked 30, T&T customs axle trusses, ProComp 35" Mud Terrain, RE SD 4" Lift, Daystar 1" BL, Harbor Freight 8000 Winch, Swing Away Tire Carrier, and some other stuff.
brinoff is offline
post #9 of 25 Old 03-20-2009, 03:10 PM
TheNewbie
I think I'm gonna need to see some pics of this.
Oh wait, did someone already say that?
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #10 of 25 Old 03-20-2009, 03:19 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Pics or BAN!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #11 of 25 Old 03-20-2009, 09:20 PM
RockWoRM
RockWoRM's Avatar
You can read my sig... I clear 35's... barely. I'm on new springs, so I'd say your springs are sagged a bit.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #12 of 25 Old 03-21-2009, 11:06 AM
OneCleanYj
I clear 35's with my set-up, well in the rear anyway. I don't think even tube fenders would keep my 35's from rubbing up front
And yes, PICS please
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline
post #13 of 25 Old 03-21-2009, 02:03 PM Thread Starter
snou52
i could be wrong...looking closer at it, it doesn't really seem like 4", i could be wrong...anyone want to help out? thanks for all the input
Yeah i'm trying to get the handling a little bit better on the roads...she's not TOO bad right now...she wanders a bit on the freeway, but i figure that's normal for a yj?
if i wanted to get rid of the body lift or switch shackles do i have to modify drivelines or do any other suspension work? i'm trying to keep this as cheap as possible i currently have a transfer case drop.
snou52 is offline
post #14 of 25 Old 03-21-2009, 02:04 PM Thread Starter
snou52
snou52 is offline
post #15 of 25 Old 03-21-2009, 02:13 PM
Barrio
Looks like 3" body lift on top of the stock body mounts......scary.
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline
Suspension Lift VS Body Lift......TIRES? TCzyzak TJ Wrangler Technical Forum 20 06-23-2009 08:51 PM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 06:32 PM
Rough Country X series 6in lift w/ 35in tires? RakHard-187 TJ Wrangler Technical Forum 34 03-28-2009 06:28 PM
i have a lift with shackles, can I put a 1" body lift as well? yjJeff YJ Wrangler Technical Forum 8 02-09-2009 10:54 AM
Tires rubbing...Body vs Suspension Lift on a budget 92yjokc YJ Wrangler Technical Forum 32 09-12-2008 08:16 PM
