4H works but 4L doesn't - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4H works but 4L doesn't
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 12-10-2010, 03:20 PM   #1
djfred
Hey,
So last time i was on a trail with my buddies, i got stuck on a hill.
I was going up on 4H, i went back and put it on 4L and my buddies noticied that the front wheel wasn't spinning.
on 4H the light comes on and front wheels spin.
but on 4L light comes on but front wheels don't spin.
Any suggestions?
EDIT: forgot to mention that i can feel the 4L some how kicks in cause when i put it in 4L, and I let go of the clutch without gassing it the car goes.
Thank you
--Now--
White 92 YJ -- RE 1.5" SOA -- BFG KM2 35x12.50x15 -- D30 (4.88 w/ ARB) -- Ford 8.8 (4.88 w/ ARB)
Sanden OBA (Click for How-To)
--Future Mod--
Flat Fenders
djfred is offline   Reply With Quote Quick reply to this message
Unread 12-10-2010, 03:43 PM   #2
SpideYJeep
Do you still have the stock vacuum set up and stock vacuum lines?
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline   Reply With Quote Quick reply to this message
Unread 12-10-2010, 03:51 PM   #3
djfred
yes the vacuum lines are stock and so is the front axel
--Now--
--Future Mod--
Flat Fenders
Unread 12-10-2010, 03:52 PM   #4
Destr0
Have you tried 4H again since then to make sure it is still working? Maybe your vac disco died like so many do about the same time... Just a thought...
Destr0 is offline   Reply With Quote Quick reply to this message
Unread 12-10-2010, 03:59 PM   #5
djfred
yes on the trail once 4L wasn't being helpful i put it back in 4H and spun my front tires and got me out.
I have been tracing the vacuum tubes all morning trying to see if anything got disconnected or anything but they all seem fine.
Ill be hitting the trails this weekend again ill test it out.
--Now--
--Future Mod--
Flat Fenders
Unread 12-11-2010, 11:53 AM   #6
Mywrangler94
Sounds like a T-case problem not a vacuum problem If you have the vacuum available when you throw it into 4H, it is still available in 4L. If its getting cut off then I would check the vac switch at the T-case...and take it from there....just MHO
Mywrangler94 is offline   Reply With Quote Quick reply to this message
Unread 12-11-2010, 12:32 PM   #7
builder
When in 4L do you get 2L or just no front engagement?
95 YJ
builder is offline   Reply With Quote Quick reply to this message
Unread 12-11-2010, 09:29 PM   #8
hh65pilot
Do you have a body lift? Try shifting with the shift boot removed or loose.
hh65pilot is offline   Reply With Quote Quick reply to this message
Unread 12-13-2010, 10:06 PM   #9
djfred
no body lift,
Solved issue.
I reset the Vacuum lines and now it works just fine.
--Now--
--Future Mod--
Flat Fenders
