4cyl motor mount replacement - JeepForum.com
post #1 of 19 Old 12-12-2011, 03:25 PM Thread Starter
VirginJeeper
So i failed VA safety inspection today. Apparently the motor mount on the drivers side is bad. I am planning to replace it myself as they want $500 to do it! So i did a search and found great info and went down to the jeep to take a look to size things up. Can somebody chime in for advice on getting these out?
The passenger side looks as though the bolt will git the alternator and the drivers side looks like a bear as for all the things in the way I will have to move. I'm feeling pretty confident in my ability to tackle this but I'm worried that I'll run into an "uh-oh" and get stuck with a motor sitting on a floor jack and block of wood. Thanks as always for any advice.
VirginJeeper is offline
post #2 of 19 Old 12-12-2011, 03:32 PM
moonshinefuel
500 dollars! Geezus..
Support the engine from underneath, two bolts, one topside, one under, and the long bolt through the mount. That one went out on me twice. Just good solid support underneath, that's your main concern, and hammer that biotch in. (with wrenches), and sockets
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 19 Old 12-12-2011, 03:40 PM Thread Starter
VirginJeeper
How do you guys get that long bolt out on the passenger side? If you push it forward it will hit the alternator and wont come out. Did you remove the entire bracket from the engine block?
I think the shop (you have to go to an inspector at a mechanics shop in VA) is a friggin rip off and over charge you because they know you HAVE to get it done to pass. You should of seen his face when I told him to get stuffed I'll do it myself!
post #4 of 19 Old 12-12-2011, 04:09 PM
moonshinefuel
If it were me, and there is no problem with the passengers side mount, leave it in there. That side has never given me a problem. And don't take both mounts out at once, do one side at a time, and if you need to get that bolt out of the passengers side mount, then remove whatever you have to that's in your way.
Bow Hunting
post #5 of 19 Old 12-14-2011, 08:15 AM Thread Starter
VirginJeeper
Yeah to get it inspected I could do that but I'm the type to just donut all the same time. I'm looking at quadratec's engine and trans mount kit. Any input? Stock 95 no lift no intention to lift.
post #6 of 19 Old 12-14-2011, 08:25 AM
sprngrider
I ordered that kit when my trans mount shredded. It is a good replacement for the stock parts. Btw, my drivers side mount failed, but the passenger side never has and looks perfect.
1994 2.5L WRANGLER S.
sprngrider is offline
post #7 of 19 Old 12-14-2011, 09:23 AM
jode
I just replaced both of mine this past week. They were both bad. The driver's side rubber had let go and on the passenger side, the outside bolt had stripped out of the frame and so the upper part of the motor mount was able to lift up to the point that the metal plate on the bottom part of the motor mount cracked in half.
For me, the driver's side was super easy because all this work happened to coincide with me replacing my head gasket so I had the PS pump, intake, exhaust, etc all disassembled. Access was no problem.
It was, nevertheless, a biotch of a job. The bolts were on there SUPER tight. I had to use a breaker bar to get them loose and even with the breaker bar I really had to put my back into it. In your case, without removing all the parts I did, maneuvering a breaker bar around in there is going to be tough.
My advice would be to get some PB Blaster on all three bolts on both mounts as soon as possible. Then, as mentioned above, do only one side at a time. I have no lift, so I was able to use the stock jack in combination with a block of 2X4 wood (to cushion the oil pan) to support the engine and to adjust the height of the engine to get everything to line up to get all the bolts back in.
To take care of the stripped out passenger side bolt hole, I just bought a nut for the back side of the bolt. It was quite difficult to get the bolt started way up inside the frame like that, but we eventually got it started and I was able to slide a wrench in to hold the nut while my buddy tightened the bolt from the topside.
For me, there was no need to move the alternator at all to access the passenger side mount - it was no problem. However, if moving the alternator is the worst of your problems, I'd say you are in pretty good shape - that's a pretty easy job.
Hung like Einstein and smart as a horse...
90 YJ, 2.5L, 5-speed
jode is offline
post #8 of 19 Old 12-14-2011, 10:18 AM Thread Starter
VirginJeeper
Wow thanks guys. It seems there has been a chain of events occurring in my jeep, a strange rattle from the rear, random trouble getting the shifter in gear, and an exhaust leak the inspector said could be anywhere in the system. Could it be that a failed engine mount could start this chain reaction? I'll be replacing it this weekend so I'll take some pictures and report in. Thanks for the advice and reassurance.
post #9 of 19 Old 12-15-2011, 01:57 AM
TA-YJ
It could be. Depending on how bad your motor/trans mounts are it could have been thrashing around in there. When I replaced mine the rubber was completely torn on one and tearing on the other. The trans mount was pretty trashed too. Its not hard to replace. An afternoon with a couple of sockets and a jack and youre good to go.
1992 YJ 2.5L
Engine Mods:4.0L TB, Ford Design III 19lb Injectors, Firepower Ignition System, Ford TBird Electric Fan, Pacesetter Header, Magnaflow Cat, Dynomax Super Turbo Exhaust
Suspension Mods:BDS 2" Lift, M.O.R.E. 5/8" HD Shackles, 1" Brown Dog MML
Other:LED Tails and Herculined
TA-YJ is offline
post #10 of 19 Old 12-15-2011, 07:42 AM
89WhyJ
$500??? Stinking Northern Virginia (I'm in Stafford by the way).
I replaced both of mine about two years ago. It was actually the first repair I made to my Jeep after I got it. All I needed was a set of sockets, cheater bar, wobble for the sockets, a floor jack, and pry bar...oh and a lot of PB Blaster. The passenger side is pretty easy. Like it was stated before, just do one side at a time and don't jack the engine up too high, just enough to take the pressure off the mounts. The wobble for the socket extension was necessary for the driver side mount. I found that the hardest part was getting the holes to line up for the cross bolt. I've got a set of pry bars, and one of them is round and tapers to a point. I jammed that in the cross bolt hole and was able to move everything around to line up the holes. That made things so much easier.
89WhyJ is offline
post #11 of 19 Old 12-15-2011, 11:54 AM
TA-YJ
Oh I forgot to mention, if you do this DONT FORGET TO LOOSEN YOUR TRANS MOUNT. If you dont it will not only make it a ***** to move the engine, but it will also probably destroy your mount.
1992 YJ 2.5L
TA-YJ is offline
post #12 of 19 Old 12-21-2011, 09:43 AM Thread Starter
VirginJeeper
My plan is to replace all the mounts at the same time as it seems like a good idea. There is a kit from quadratec that has both engine and trans mounts and a torq bolt. What is the significance of this bolt? Should I plan on reaching the existing bolts on all the mounts as well? Also what are you guys torquing the bolts to?
post #13 of 19 Old 12-21-2011, 10:54 AM
89WhyJ
Here's all you need to know about replacing the trans mount:
http://www.jeepforum.com/forum/f12/t...cement-903109/
89WhyJ is offline
post #14 of 19 Old 12-21-2011, 02:06 PM Thread Starter
VirginJeeper
Thanks. I'm looking for the torque for these bolts and didn't see that info. Any ideas in torque spec for engine mounts and trans mounts? Is this something a fsm would have?
post #15 of 19 Old 12-21-2011, 02:18 PM
89WhyJ
I think that info is in the Haynes manual. I'll look when I get home.
89WhyJ is offline
02 TJ I6 Motor Mount Replacement Pictorial MeatPuppet TJ Wrangler Technical Forum 20 03-23-2016 05:43 PM
Replacement Motor Mount Through Bolt blk97tjse TJ Wrangler Technical Forum 9 01-02-2011 10:00 AM
Motor Mount Replacement youngYJ95 YJ Wrangler Technical Forum 4 11-08-2010 01:13 PM
motor mount replacement YJames90 YJ Wrangler Technical Forum 7 01-19-2008 06:00 PM
I4 motor mount replacement G&CS YJ Wrangler Technical Forum 2 01-05-2004 09:25 PM
