4cyl drivetrain length vs 6 cyl length - JeepForum.com
post #1 of 3 Old 03-06-2013, 06:26 AM Thread Starter
89yj33
hey guys im going to look at some axles this morning, guy has them set up for soa with high steer, getting a good deal so so it will be hard to pass. However should i get driveshafts too? i have 6 cyl he has 4cyl.? how much different in length are they?
front waggy 44, rear scout 44, sye, 1.5 re soa springs
my set up will be sye, stock yj springs with added main leaf(only for month at most gotta get funds for re soa springs)
89yj33 is offline
post #2 of 3 Old 03-06-2013, 07:33 AM
bogleparsons
the axles are all the exact same, it's the transmission and engines that cause the drive shafts to be different. So your good to go.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #3 of 3 Old 03-06-2013, 08:43 AM Thread Starter
89yj33
I should have made it more clear. He has a 4cyl ax5 231 set up. I have 6 ax15 231. I'm asking if you guys think it would be worth it to try and grab driveshafts. Do you guys think they would be that much off?
89yj33 is offline
