4cyl with 35's???? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4cyl with 35's????
Iron Rock Offroad products - get them from Kolak!WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 02-28-2009, 07:40 PM   #16
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Originally Posted by OneCleanYj View Post
've never seen anyone in the YJ Forum claim they can pull that
it was called humor and sarcasm for all the 4 banger lovers.....read on my friend, some will defend it with their dyeing breath.
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
leftlanetruckin is offline   Reply With Quote Quick reply to this message
Unread 03-01-2009, 12:48 PM   #17
OneCleanYj
martin
I know it was, I was just saying my friend
I defend mine, but not to death. I think it just truly varies from Jeep to Jeep. One of these days though, mine will find a home in another Jeep after I do a swap
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline   Reply With Quote Quick reply to this message
Unread 03-01-2009, 01:05 PM   #18
MYYJ93
I'm runniing 33's with the 2.5 and 4.10's. I've never been disappointed on the trails however over the road unless I'm going down hill I don't see 5th gear much. Going up any sizable hills I use third gear. Its not my dd so it doesn't bother me much. I am thinking of regearing though.
MYYJ93 is offline   Reply With Quote Quick reply to this message
Unread 03-01-2009, 05:12 PM   #19
justanotherhemi
I was going to run 35 but just like you i did some research and found that not only would 5th be useless but the D35 would fail sooner or later. I regeared the D35 with 4 88s and went with 33s and has worked great.
l _____
/l ,[____],
l---L []lllllll[]-
()_)-()_)--o-)_)
justanotherhemi is offline   Reply With Quote Quick reply to this message
Unread 12-17-2011, 09:16 PM   #20
offroad349
Originally Posted by Bigboyky View Post
I run 33's with them little squirrel's screaming at me...... 5th gear what's that? I am regearing very soon. But 35's, why would someone do that?
I run a 2000 2.5L on 35's with 4.88 gears and can do 70mph no problem on the highway. But your right without re-gearing anything bigger than 33 and 4.11 is worthless
offroad349 is offline   Reply With Quote Quick reply to this message
Unread 12-17-2011, 09:40 PM   #21
plumber1
WOW some of you guys must get a lot more power out of your 4 cyl than I do. Mine SUCKED when I went up to 33's from 31's. Now once I re-geared to 4:88's to does very well, not sure if it well enough for 35's.
But 33's on stock 4:10's is ok 35's no way.
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline   Reply With Quote Quick reply to this message
Unread 12-17-2011, 10:00 PM   #22
91BoD
Bottom line: If you want a larger then stock DD jeep wait for a 6cyl unless you are planning a motor swap.
The 4cyl just doesn't have the ponies to push a billboard down the freeway on the daily.
Coming from the guy building a 4cyl with 33x12.5s
If you can't afford a 6 or get a great deal on a 4 then by all means whatever gets you on the trail!
91BoD is offline   Reply With Quote Quick reply to this message
Unread 12-18-2011, 09:08 AM   #23
Xpress
A DD shouldn't have 35's on it... That's defeating the purpose of a DD. A DD is a fuel efficient vehicle that you use to get from point A to point B, not something you can crawl over traffic
You might manage a whopping 12mph going downhill. That being said, my YJ has a 3.55 rear axle right now and even so with 29" tires I can do highway speeds. Takes a bit of time to get there but once i do I can get to 65 no problem. As long as I stay out of 5th gear I can even hit 75-80mph going down some slopes. But I don't ever do that because it sucks enough gas already.
The 4 banger is a very tough engine. It's amazing at what can be wrong with it and they will still purr like a kitten.
All about that unibody life.
Xpress is offline   Reply With Quote Quick reply to this message
Unread 12-18-2011, 11:20 AM   #24
Shenandoah
For what it's worth, I have 4:88's with 33's in the 2.5. I drive over the Blue Ridge Mtns every day to work. I have to use 3td on the steep parts of rt 250. I can't keep enough speed to use the interstate going west (steeper incline). On flat ground, I can use 5th and go 70-75 no problem.
For those who say they have no problems on inclines, define incline.
Turn a wrench, save a tree
Shenandoah is offline   Reply With Quote Quick reply to this message
