410's or 456's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 410's or 456's
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!FLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-05-2002, 07:47 PM   #1
highonthai
410's or 456's
4.2 with 33's, should I go with 410's or 456's?
Thank's
highonthai is offline   Reply With Quote Quick reply to this message
Unread 04-06-2002, 05:53 AM   #2
Patton
I would lean more towards the 4.56 if you have a Overdrive transmission. If it is an automatic the 4.10's is the lowest option you have unless you never plan to get over roughly 55 mph. The pinion gear on a 4.10 will generally be stronger than that of a 4.56 of the same brand. I would look for original 4.10's out of 4 cyl that are as close to new as possible. You just can;t beat the Dana/Spicer gears for reliability and fit perfection.
94 YJ 4.0/3spd dana 60/44 w/35's 9" of suspension lift
Sold-06 TJ X 4spd auto 3.73
Patton is offline   Reply With Quote Quick reply to this message
