410's or 456's - JeepForum.com
post #1 of 2 Old 04-05-2002, 07:47 PM Thread Starter
highonthai
410's or 456's
4.2 with 33's, should I go with 410's or 456's?
Thank's
highonthai is offline
post #2 of 2 Old 04-06-2002, 05:53 AM
Patton
I would lean more towards the 4.56 if you have a Overdrive transmission. If it is an automatic the 4.10's is the lowest option you have unless you never plan to get over roughly 55 mph. The pinion gear on a 4.10 will generally be stronger than that of a 4.56 of the same brand. I would look for original 4.10's out of 4 cyl that are as close to new as possible. You just can;t beat the Dana/Spicer gears for reliability and fit perfection.
94 YJ 4.0/3spd dana 60/44 w/35's 9" of suspension lift
Sold-06 TJ X 4spd auto 3.73
Patton is offline
6cyl auto 410's now! snow camo woot woot dream911tommy YJ Wrangler Technical Forum 16 12-20-2008 09:51 AM
456's or 488's? skoke70 TJ Wrangler Technical Forum 6 05-18-2005 03:41 PM
410' or 456's? roadking TJ Wrangler Technical Forum 17 01-07-2005 12:34 PM
