4 wheel indicater light help - JeepForum.com
post #1 of 7 Old 01-19-2012, 08:20 PM Thread Starter
Putz
hello all,
I pull my shift leaver into 4 high and the light comes on. The light stays on for the most part but as soon as I give it a good goose to climb a hill the light goes out. Now I have 3 questions. 1 Is my jeep in 4 wheel drive at all in the beginning? 2 Why is the light going out? 3 Is it coming out of 4 wheel drive when the light goes out when I goose it to climb a hill? I'm wandering if it isn't a vac. problem or if it has something to do with the after market air cleaner that was on it when I bought it(maybe something with it pulling not enough vac because of it)Any help would be appreciated.
Thank You
Putz is offline
post #2 of 7 Old 01-19-2012, 09:04 PM
Xpress
I think they went to electronical switches for that year for the 4wd light. Might want to check the connections on the vacuum shift actuator on the front axle, passenger side.
All about that unibody life.
Xpress is offline
post #3 of 7 Old 01-19-2012, 09:52 PM
jeepinvader
When you hit the gas, the vacuum pressure decreases, which could cause the vacuum actuator at the axle to disconnect, turning off your 4wd and the light. Like Xpress said, I'd start by checking the connection to the actuator on the axle. Keep us updated.
Free Chuck!
jeepinvader is offline
post #4 of 7 Old 01-20-2012, 09:00 AM
dancytron
The checkvalve (the first one on the red line) prevents that when it is working right.
dancytron is offline
post #5 of 7 Old 01-20-2012, 11:12 AM
1998zj
Mine does the same thing. It doesn't come out of 4wd, it moves just enough to come off of the switch.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #6 of 7 Old 01-20-2012, 12:11 PM
TheRobster
You might want to read through this:
http://www.jeepforum.com/forum/f12/4...stion-1316145/
Check out my cheep bastard Jeep mod blog.
TheRobster is offline
post #7 of 7 Old 01-20-2012, 09:32 PM Thread Starter
Putz
Thanks Guys I'll look at it tomorrow.
Putz is offline
4 wheel drive light won't come on kampoyj YJ Wrangler Technical Forum 7 12-02-2010 05:15 PM
4 wheel drive light khill8469 TJ Wrangler Technical Forum 7 07-19-2010 07:15 PM
open door light/buzzer indicater yj_beater51 YJ Wrangler Technical Forum 4 05-29-2009 07:54 AM
4 Wheel Light graywolffvly YJ Wrangler Technical Forum 7 06-27-2005 06:41 PM
4wd indicater light not working vermontjeep TJ Wrangler Technical Forum 3 04-04-2005 09:23 AM
