4 wheel driver stick shift - JeepForum.com
post #1 of 9 Old 07-19-2004, 06:35 AM Thread Starter
hguffman
hguffman's Avatar
Ok I know something isn't lubricated but I am not sure what.
I have a few things going on. First, my four wheel isn't working, and I installed the posi lock so I now that my front wheels should be locking in. but I just noticed that my stick shift (for the 4wd) get real hot while driving down the road (4wd is not engaged). and I have an incling that it might be related?
also, in first gear sometimes I get serious shakes off the line. It usually happens after I have been driving around a little bit and the jeep is hot. But other times, like after driving down the highway a little bit it won't... anyone else had these symptoms?
Brian
89 Wrangler 4.2L w/ Posi-Lok, Weber Carb, Electric Cooling Fan
THE RED SOX WIN THE PENNANT!!! THE RED SOX WIN THE PENNANT!!!!
THE RED SOX WIN IT ALL!!!!!! WORLD CHAMPIONS BABY!!!!
hguffman is offline
post #2 of 9 Old 07-19-2004, 09:20 AM
JayJEEPguy
JayJEEPguy's Avatar
Serious vibrations on take-off after it's hot?
Yeah, I feel your pain...My Jeep likes to act up sometimes, too.
My hydraulic clutch line was leaking. After I changed it and bled the clutch, it has been much better, although occassionally I still get some vibes in First. I think my clutch may be on its way out.
Have you checked the clutch fluid lately?
Have you checked ANY of the tranny/t-case fluids lately? By the description of a hot 4wd lever, I'd say you could possibly be well on your way to burning up your t-case
Jason T.
'99 GMC Suburban: Gas-guzzling people mover with 18" Z71 wheels
'04 WJ:Special Edition. V8, QTII, 2"BB, Bilsteins & 245/75/16" Goodyears
'02 WJ:4.7L, Selec-Trac. Totalled 9-12-07. Click to hear
JayJEEPguy is offline
post #3 of 9 Old 07-20-2004, 06:02 AM Thread Starter
hguffman
hguffman's Avatar
I figured as much, about the t-case... tranny fluid is fine but t-case leaks alot and needs attention all the time.
I just had a entirely new clutch put in. the vibrations drive me crazy because it only happens sometimes... but always when after its its been running. I fear though by the time I diagnose it something is going to fall off. =)
Brian
hguffman is offline
post #4 of 9 Old 07-20-2004, 06:39 AM
JayJEEPguy
JayJEEPguy's Avatar
That's lousy, man.
I dunno what to tell ya about the "shakes".
Mine def. became worse the more I used the clutch....
Jason T.
post #5 of 9 Old 07-20-2004, 06:09 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
sure you're just not lugging the engine by letting the clutch out a little too fast? I don't mean to say that you don't know how to drive it, but I know i do that sometimes. my clutch is brand new and it did it to me the other day. i know it's just that I didn't give it enough gas before popping it. as for the hot t-case lever, defintiely sounds like you've got low/no fluid splashing around in there. did it do this before and after you put in the posi-lok?
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #6 of 9 Old 07-21-2004, 05:55 AM Thread Starter
hguffman
hguffman's Avatar
Yeah, there is a chance it could me lugging the engine, because I have been paying more attention to letting the clutch out lately and it has got better. So that could all just be me.
As for the t-case, I am pretty sure, not positive, but pretty sure it wasn't heating up the lever before I put the posi-lok in... but does that make sense, it could be that I just didn't notice it before, but that baby gets pretty warm... enough for me to feel the radiant heat on my leg when I wear shorts. The first time I noticed it I thought the heat was on.
Brian
hguffman is offline
post #7 of 9 Old 07-21-2004, 06:03 AM
JKNIPE2000
JKNIPE2000's Avatar
i get the vibes on takeoff sometimes too, but mine is because my front left brake hangs up and its harder to take off. might want to check your brakes/brake fluid.
Gone but not Forgotten:
1990 Islander O.D. Green
Currently no Jeep, but I'm in the market
JKNIPE2000 is offline
post #8 of 9 Old 07-21-2004, 07:07 AM
JayJEEPguy
JayJEEPguy's Avatar
Well, I went 'wheelin last night, and I can most definitely tell that my vibes are CLUTCH related. If I don't slip the heck out of the clutch now when taking off, the entire Jeep shudders like mad.
Wonder if a weak slave cyl. would cause this?
Jason T.
post #9 of 9 Old 07-21-2004, 08:48 AM
coolhand
coolhand's Avatar
My guess about the vibes would be that your old worn out springs are alowing axle wrap and causing your U-Joints to bind up.
As for the hot shifter I would make sure the posi-loc is fully disengaged and the T-case is full of ATF.
HTH
"The Empty Pocket Warriors." Member #2
"92 YJ, 3.5" BDS. Custom 1.5" lift shackles, 2" BL, Ford 8.8 W/Trac-loc & 33" TrXus MT's (for now).
"No one ever accused the Wrangler of being comfortable, quiet, or practical. No one ever called it boring, either. The Wrangler is a two-door toy, ... great fun to drive with the top down." -- AUTOMOBILE MAGAZINE, March 1995.
coolhand is offline
Stick shift difficulty warCryr JK Wrangler Technical Forum 29 03-18-2009 10:15 AM
Stick Shift... Tompatt YJ Wrangler Technical Forum 6 01-24-2009 04:48 PM
Stick Shift Printed Cap MikeBW TJ Wrangler Technical Forum 21 09-05-2008 09:18 AM
Shift Stick broke off hotzy21 YJ Wrangler Technical Forum 6 08-24-2008 04:25 PM
Noise from stick shift area, and Steering wheel itchyandscratch TJ Wrangler Technical Forum 3 10-05-2002 08:28 PM
