4 wheel drive vacum issue - JeepForum.com
post #1 of 7 Old 09-07-2011, 06:41 PM Thread Starter
markym
Hi i just bought a 1990 wrangler the 4 wheel drive seems to work but the vacum lines going to the front axle are cut or dry rotted.. so my question is what do they do? thanks
markym is offline
post #2 of 7 Old 09-07-2011, 06:59 PM
dancytron
Search CAD or Posilok. There are dozens of threads. Also in FAQ
dancytron is offline
post #3 of 7 Old 09-07-2011, 07:01 PM
dtn8tr
How do you know that the 4WD is working? The vacuum lines engage and disengage the passenger side axle.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #4 of 7 Old 09-07-2011, 07:06 PM Thread Starter
markym
well i put in 4 wheel no light came on so i put in 4 wheel low and it was crawling low low gear so asumeed it was working.. do you think i can mend them with vacum lines and be good to go?
markym is offline
post #5 of 7 Old 09-07-2011, 07:09 PM
dancytron
Probably. You can use regular black lines from autoparts store.
http://www.jeepforum.com/forum/f12/4...uging-1261215/
post #6 of 7 Old 09-07-2011, 07:17 PM Thread Starter
markym
so at this point i only have a 3 wheel drive jeep untill i fix my lines??
markym is offline
post #7 of 7 Old 09-07-2011, 07:57 PM
Hillbilly Jeep
i had my vaccume lines fall on my exaust and melted like a 4 inch section of all the lines together and what i did was buy black vaccume lines from advance.. cut the bad sections out and use the black lines in place of the melted ones.. used rubber cement and zip ties.. with no problems.. its a quick easy cheap fix
Hillbilly Jeep is offline
4 wheel drive issue coopstain YJ Wrangler Technical Forum 5 12-31-2009 01:44 PM
transmission issue ? drive shaft issue ? clutch issue..where to begin ?..... rthompson48082 YJ Wrangler Technical Forum 7 09-28-2009 06:07 PM
how do i fix my 4 wheel drive - when in 4wheel drive only one wheel turns c-wag YJ Wrangler Technical Forum 3 06-01-2009 11:45 AM
YJ 4-wheel drive not working, Issue is with Transfer case, Want to do it myself. IronFalcon YJ Wrangler Technical Forum 1 01-31-2009 03:32 PM
4 wheel drive issue standnstillfast YJ Wrangler Technical Forum 2 03-01-2005 02:24 PM
