4 Wheel Drive problems - JeepForum.com
post #1 of 2 Old 06-24-2001, 03:19 PM Thread Starter
Hogmaster
I just got my '89 YJ the other day and I've been unsuccessful in engaging 4 wheel drive to this point. When I try to shift it into 4 wheel (high or low), the gearing on the rear seems to change, but the front wheels don't turn. We've had it up on stands in an attempt to find the problem, but our experience is limited with jeeps and 4 wheel drive systems in general. There is no grinding or any type of bad indication, there is just no drive to the wheels. Are we missing a step here? Or is this an indication of a bigger problem? Thanks for the help. Please send responses to J_Gris@yahoo.com .
-Jason
Hogmaster is offline
post #2 of 2 Old 06-24-2001, 04:26 PM
lostboy
check the vacuum lines that run to the front axle...and if you can ...get a chilton's or haynes manual for the jeep ....it's invaluable :
89 yj w/ mopar mpi and 4.0 head.94 ax-15 tranny and t-case, more mods comin.
lostboy is offline
Is it a bad thing to drive in 4 wheel drive moonlight TJ Wrangler Technical Forum 29 02-08-2010 10:33 PM
four wheel drive problems ausra15 YJ Wrangler Technical Forum 8 11-15-2009 07:33 PM
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 11:58 PM
how do i fix my 4 wheel drive - when in 4wheel drive only one wheel turns c-wag YJ Wrangler Technical Forum 3 06-01-2009 11:45 AM
4 wheel drive problems sihatch YJ Wrangler Technical Forum 3 05-30-2008 10:33 PM
