4 wheel drive play? - JeepForum.com
post #1 of 13 Old 08-28-2013, 06:29 PM Thread Starter
Haggerty
4 wheel drive play?
so i was checking my four wheel drive today and i started the jeep, and jacked one front wheel off the ground and i checked how much i could spin it and i got 25-30 degrees, i figured that was too much, and that i shouldn't really have any play. but i can do 4 wheel burn outs on dirt roads and i can feel it locked up when i turn. i just want to figure out if its too much. thanks
Haggerty is offline
post #2 of 13 Old 08-28-2013, 07:56 PM
taylor797
That seems pretty normal to me. You have to remember everything that your spinning, a little bit of play in each u joint, gears, t case adds up
taylor797 is offline
post #3 of 13 Old 08-28-2013, 08:04 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
With it started & one front wheel off the ground & still in 2wd, you are not checking the 4wd operability if thats what you were thinking.
Also, since you have not filled out your profile, we have to guess if you are still running stock differentials.
Joe Dillard is offline
post #4 of 13 Old 08-28-2013, 08:14 PM Thread Starter
Haggerty
it was running and in 4wd, and i replaced all the vacuum lines a while back, i have the stock axles. and one front wheel was off the ground
Haggerty is offline
post #5 of 13 Old 08-28-2013, 08:36 PM
Joe Dillard
With it running & the tcase in 4wd (assuming the tranny was in neutral) there NEEDS to be movement of the front axle components before the vacuum disconnect collar engages UNLESS the remote possibility happens and the passenger side two piece inner axle shaft splines are lined up.
In other words - most of the time the differentials & axle shafts will need to spin some before the collar finds the sweet spot & allows for the axle shafts to lock together.
post #6 of 13 Old 08-28-2013, 08:38 PM
Joe Dillard
This collar slides over & locks the 2 piece inner passenger side axle shafts together before 4wd can occur. This happens by way of vacuum from the tcase and a CAD system.
post #7 of 13 Old 08-28-2013, 08:40 PM Thread Starter
Haggerty
I drove forward and in reverse, probably 4-500 feet to make sure it locked in
Haggerty is offline
post #8 of 13 Old 08-28-2013, 08:42 PM
Joe Dillard
Ahh, I see (now that you are back filling us).
post #9 of 13 Old 08-28-2013, 08:48 PM Thread Starter
Haggerty
sorry guys, so you think its alright?
Haggerty is offline
post #10 of 13 Old 08-30-2013, 12:45 PM Thread Starter
Haggerty
Bump
Haggerty is offline
post #11 of 13 Old 08-30-2013, 02:22 PM
jokerchief462
Drive it like you stole it!!!
These things are old and yes there is some slack even in new ones its fine enjoy it!!
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #12 of 13 Old 08-31-2013, 12:30 PM
rambo3489
Your fine. As stated above even with all new parts you will have play. It all adds up.
Drive the crap outta it until it breaks.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #13 of 13 Old 08-31-2013, 12:39 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by Haggerty View Post
.... jacked one front wheel off the ground and i checked how much i could spin it and i got 25-30 degrees,...want to figure out if its too much. thanks
There is no tire spin, backlash measurement, doing so shows you nothing.
If the gears are not making excessive noises, it should be fine. The proper inspection would be to check backlash and gear pattern at the ring and pinion.
CJ7-Tim is offline
