4 wheel drive not working - JeepForum.com
post #1 of 38 Old 02-24-2012, 07:51 AM Thread Starter
mbecnel
I have a 91 yj that the 4wd is not working. Does the 4wd engage electronically?
mbecnel is offline
post #2 of 38 Old 02-24-2012, 08:00 AM
Andywear
NO not electric, the fork in the front axle is shifted by vacume hoses, if your hoses are split or not hooked up the 4WD will not engage.
But there could be acouple other problems.
Could you give more information? What does it do, why are you under the assumention its not in 4wd?
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #3 of 38 Old 02-24-2012, 08:17 AM Thread Starter
mbecnel
Trying to sell it. While test driving we went into field put it in 4wd drive. Rear wheels would spin in clovers but not front
mbecnel is offline
post #4 of 38 Old 02-24-2012, 08:24 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It's probably your CAD. It's always the CAD.
Luck Favours The Prepared
Anticanman is offline
post #5 of 38 Old 02-24-2012, 09:00 AM
spawnofsatan
You prob don't have to Vac to the CAD..
spawnofsatan is offline
post #6 of 38 Old 02-24-2012, 09:22 AM Thread Starter
mbecnel
what is the CAD
mbecnel is offline
post #7 of 38 Old 02-24-2012, 10:37 AM
Andywear
I beleive its your vacume system or maybe the diaphram thats on your front axle.
Andywear is offline
post #8 of 38 Old 02-24-2012, 11:05 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Central axle disconnect.
Lock your fork like this to fix it. Takes pliers, rtv, and 20 minutes of your life.
post #9 of 38 Old 02-24-2012, 11:08 AM
monkeyhouse
It should run off vacuum(depending on whether it's been modified). How is it not working? What I mean is, is the 4wd light coming on?
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #10 of 38 Old 02-25-2012, 07:59 AM Thread Starter
mbecnel
updated info
Update
4wd light not on. Front axle spins freely in 2wd and doesn't spin in 4wd. I disconnected the two lines from the top of control motor. I have a vacuum in 2wd but not in 4wd.(I had both lines disconnected at same time). Trace lines in engine compartment.........1 is not connected to anything (looks like a filter on end) the other is connected to a T with one going to engine and one going thru fire wall.....................see pics
What next
mbecnel is offline
post #11 of 38 Old 02-25-2012, 08:20 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Re read my picture post. That'll fix it permanently.
post #12 of 38 Old 02-25-2012, 08:22 AM
bogleparsons
^ agreed, I did it and haven't looked back since.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #13 of 38 Old 02-25-2012, 08:24 AM Thread Starter
mbecnel
I see your post but I really don't know what I'm looking at.........give me a clue. Will it be locked in 4wd permanently?
mbecnel is offline
post #14 of 38 Old 02-25-2012, 08:28 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That's a pic of the E-clips holding the fork onto the shaft. The vacuum moves that shaft inside the actuator and the fork just rides along sliding the collar which locks/unlocks the two piece shaft. This modification locks the shaft in place with the fork so that it is permanently locked in a solid state. The only action needed to turn from 2wd to 4wd is now mechanical at the front yoke of the transfer case. No vacuum needed.
post #15 of 38 Old 02-25-2012, 08:31 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
In the picture, the fork is usually locked between the two clips on the shaft, all you have to do is remove the clip opposite the side with the brass fitting in the picture, move the fork back and replace the clip in front instead of behind the fork.
4 wheel drive not working custom99 TJ Wrangler Technical Forum 5 02-22-2011 05:23 PM
4 Wheel Drive Not Working... jeepdriver1973 YJ Wrangler Technical Forum 5 07-25-2010 09:01 PM
4 wheel drive not working Gould152 YJ Wrangler Technical Forum 4 11-29-2009 01:19 PM
HELP 4 wheel drive not working '87 YJ jaret YJ Wrangler Technical Forum 7 09-15-2009 09:18 PM
4 Wheel drive not working Projekt89 YJ Wrangler Technical Forum 4 04-27-2009 07:59 AM
