4 wheel drive not engauging - JeepForum.com
post #1 of 8 Old 09-04-2011, 09:00 PM Thread Starter
gotrock88
So today while out on a run, my 4 wheel drive decided to stop working. When I got home to figure it out I checked first thing to see if I had any vacuum at the axel and there was none. After going over the vacuum lines thru out the jeep, I found that it is all jacked up and there is almost none anywhere. Then I noticed that fuel was starting to leak out of the vacuum canister. Could the two be related? So I am stumped on what to do next, any suggestions?
Thanx
gotrock88 is offline
post #2 of 8 Old 09-05-2011, 06:58 AM
danlee
1987 YJ Wrangler
The vac system is junk, in my opinion, I went to a cable style posi lock, so far so good.
danlee is offline
post #3 of 8 Old 09-05-2011, 08:13 AM
cstone94
Mine did the same. I had to replace the thing that sticks down into the t-case when 4wd is engaged from the vacuum. Ill try to get the name of it.
95' YJ - Warn Bumpers/Tire Carrier/Winch - 2.5L - 6" Skyjacker Suspension Lift - 4.10's - Locrite Locker - Dana 35/30 - 35" BFGoodrich KM2's
11' F250 - DD
1982 Toyota Pick-Up - Spray-On Yellow Rhino Lined - Chevrolet 305 H.O. - SM465 - NP208C - All-Pro Off Road 5" Springs - 35x15.50x15 Super Swampers
cstone94 is offline
post #4 of 8 Old 09-05-2011, 08:30 AM Thread Starter
gotrock88
That is my plan down the road, but for now I just need to get the thing working.
post #5 of 8 Old 09-05-2011, 08:32 AM Thread Starter
gotrock88
Did you have to remove the tcase to fix the problem?
post #6 of 8 Old 09-05-2011, 05:13 PM
cstone94
Nope
11' F250 - DD
cstone94 is offline
post #7 of 8 Old 09-05-2011, 07:08 PM
Fenix85182
Fenix85182's Avatar
Check your vacuum can underneath your battery tray. I had a vac line that used to disconnect under there all the time.
After doing my 4.0 swap, my t-case vacuum switch died--it wouldn't vent properly anymore. I think it was a $40 part from quadratec. Anyway, check your vac lines first before replacing anything. If both the lines are plugged into the vac can, trace back and look for disconnected lines. I used to have vac lines come disconnected at the back of the head by the firewall.
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
post #8 of 8 Old 09-05-2011, 08:15 PM
dancytron
The vacuum lines are 20 years old. More than likely that's the problem. If you want it to be dependable, then replace them all.
Search, there are many threads.
You should test the vacuum motor on the axle to see if it works. Get some vacuum line, jack up the front right tire, start it up in neutral (safely), and run vacuum directly to each of the ports and spin the tire to see if it locks (look to see if the front driveshaft is spinning).
Don't know about the fuel leaking, that sounds bad.
dancytron is offline
NSG370 2 wheel drive vs 4 wheel drive SharkintheWoods YJ Wrangler Technical Forum 0 05-29-2010 05:45 PM
Is it a bad thing to drive in 4 wheel drive moonlight TJ Wrangler Technical Forum 29 02-08-2010 09:33 PM
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 10:58 PM
how do i fix my 4 wheel drive - when in 4wheel drive only one wheel turns c-wag YJ Wrangler Technical Forum 3 06-01-2009 10:45 AM
no 4 wheel drive chuckyj95 YJ Wrangler Technical Forum 18 01-07-2008 01:16 PM
