4 Wheel Drive Light - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4 Wheel Drive Light
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete Building a Bumper?
Unread 07-19-2014, 08:34 AM   #1
wsmm
4 Wheel Drive Light
What would cause the 4 wheel drive light to stay on. The Jeep appears to shift into and out of 4 wheel drive just fine. Year is 1995.
wsmm is offline   Reply With Quote
Unread 07-19-2014, 10:14 AM   #2
XJ93
Check the 4wd switch.
XJ93 is offline   Reply With Quote
Unread 07-19-2014, 10:41 AM   #3
dancytron
What year do you have? There are 2 different setups.
dancytron is online now   Reply With Quote
Unread 07-19-2014, 11:26 AM   #4
wsmm
Originally Posted by dancytron View Post
what year do you have? There are 2 different setups.
1995
Unread 07-19-2014, 11:58 AM   #5
jbolty
jbolty's Avatar
your switch is at the axle disconnect motor housing. I would start with checking the vacuum hoses and make sure the disconnect is actually working, chances are it's not
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
