4 wheel drive fix - JeepForum.com
post #1 of 11 Old 05-16-2013, 05:07 AM Thread Starter
eshunter1128
4 wheel drive fix
I own an '89 wrangler the four wheel drive went on me this winter. I jacked it up and everything was spinning except the wheels so I think it's narrowed down to the four wheel drive vacuum actuator.
It looks like something's missing right here any thoughts? It would be much appreciated
eshunter1128 is offline
post #2 of 11 Old 05-16-2013, 05:30 AM
Gage56
yup thats broken , what year is it ? i may have one here i could sell ya for cheap
1992 YJ
Gage56 is offline
post #3 of 11 Old 05-16-2013, 05:42 AM Thread Starter
eshunter1128
It's an '89 is there anything I can do just to make that connection there? Or do I need to replace the whole thing
post #4 of 11 Old 05-16-2013, 05:46 AM
grandboost98
You can open the CAD and lock the fork over in 4wd so that it stays there. You might need to get your front drive shaft balanced though
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #5 of 11 Old 05-16-2013, 05:47 AM Thread Starter
eshunter1128
That would put more wear on the tires than I would want if the wheels were locked together
post #6 of 11 Old 05-16-2013, 05:49 AM
grandboost98
The wheels wont be locked together, just the two piece passenger axle. The diff is still open if its stock
post #7 of 11 Old 05-16-2013, 05:54 AM Thread Starter
eshunter1128
So would it put more wear on my tires though when I'm not using four wheel drive?
post #8 of 11 Old 05-16-2013, 06:00 AM
mudsweatNgearz
1987 YJ Wrangler
Nope. the front tires will be free wheeling independently while in 2X. I locked my shaft over and no issues at all. I am going chromo in the d30 so it's all coming out though.
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #9 of 11 Old 05-16-2013, 06:03 AM Thread Starter
eshunter1128
Thanks appreciate it wanna get it fixed before go topless day saturday!
post #10 of 11 Old 05-16-2013, 11:47 AM
jsipe007
As grandboost98 stated, the only downside to this method is that you may need to have your front driveshaft balanced. A lot of guys do this, or swap in solid TJ shafts. its a good solution to a pesky problem.
Definitely gotta go topless Saturday!
jsipe007 is offline
post #11 of 11 Old 05-16-2013, 05:34 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You may want to order a new fork if you're not going to swap in one piece shafts anytime soon. If there's that much rust outside, there's bound to be wear inside. Its only $15 with shipping.
Luck Favours The Prepared
Anticanman is offline
4x4 , actuator , fix , jeep yj , wrangler
