-   -   4 wheel drive fix (http://www.jeepforum.com/forum/f12/4-wheel-drive-fix-1524052/)
eshunter1128 05-16-2013 06:07 AM
4 wheel drive fix
1 Attachment(s)
I own an '89 wrangler the four wheel drive went on me this winter. I jacked it up and everything was spinning except the wheels so I think it's narrowed down to the four wheel drive vacuum actuator.
Attachment 627221
It looks like something's missing right here any thoughts? It would be much appreciated
Gage56 05-16-2013 06:30 AM
yup thats broken , what year is it ? i may have one here i could sell ya for cheap
eshunter1128 05-16-2013 06:42 AM
It's an '89 is there anything I can do just to make that connection there? Or do I need to replace the whole thing
grandboost98 05-16-2013 06:46 AM
2 Attachment(s)
You can open the CAD and lock the fork over in 4wd so that it stays there. You might need to get your front drive shaft balanced though
eshunter1128 05-16-2013 06:47 AM
That would put more wear on the tires than I would want if the wheels were locked together
grandboost98 05-16-2013 06:49 AM
2 Attachment(s)
The wheels wont be locked together, just the two piece passenger axle. The diff is still open if its stock
eshunter1128 05-16-2013 06:54 AM
So would it put more wear on my tires though when I'm not using four wheel drive?
mudsweatNgearz 05-16-2013 07:00 AM
Nope. the front tires will be free wheeling independently while in 2X. I locked my shaft over and no issues at all. I am going chromo in the d30 so it's all coming out though.
eshunter1128 05-16-2013 07:03 AM
Thanks appreciate it wanna get it fixed before go topless day saturday!
jsipe007 05-16-2013 12:47 PM
As grandboost98 stated, the only downside to this method is that you may need to have your front driveshaft balanced. A lot of guys do this, or swap in solid TJ shafts. its a good solution to a pesky problem.
Definitely gotta go topless Saturday! :)
Anticanman 05-16-2013 06:34 PM
You may want to order a new fork if you're not going to swap in one piece shafts anytime soon. If there's that much rust outside, there's bound to be wear inside. Its only $15 with shipping.
The time now is 08:39 PM.
