4 WHEEL DRIVE - JeepForum.com
post #1 of 6 Old 10-12-2001, 12:45 PM Thread Starter
gatt
4 WHEEL DRIVE
I RECENTLY BOUGHT A '94 WRANGLER AND THE OWNERS MANUAL DID NOT COME WITH IT. I WAS WONDERING HOW TO PUT THE JEEP IN 4 WHEEL DRIVE.
gatt is offline
post #2 of 6 Old 10-12-2001, 12:53 PM
GREGDOG95YJ
GREGDOG95YJ's Avatar
there should be a shift lever in the floor by were your right leg goes to the gas pedal the knob is marked 2H, 4H, 4L. for everyday driving on the pavement leave in the 2h position for offroad driving use the 4H and 4L position. you can order an owners manual form www.thinkjeep.com for about 10 bucks.
Jason Gregory
95 yj Rio Grande 2.5L
31" BFG MUDS, 1"BL,2" homemade spring lift, 150W KC'S, KN Filter, both air restricters gone, track bars gone, quick discos, & high flow cat
"just like all addicts my need to satisfy my addiction far exceeds my wallet!!"
GREGDOG95YJ is offline
post #3 of 6 Old 10-12-2001, 04:50 PM Thread Starter
gatt
thank you for the response, but i was wondering if i have to be rolling or stopped, the clutch in or out, things like that.
gatt is offline
post #4 of 6 Old 10-12-2001, 06:29 PM
osburn
osburn's Avatar
To go from 2hi to 4hi, they say you can be moving up to like 55 mph. Just push in the clutch and shift. But really, I'd never do that at such high speed. It's about impossible to shift the tcase if you're at a complete stop though. When going into 4lo, be rolling, but just barely.
Matt Osburn
Score 1032
osburn is offline
post #5 of 6 Old 10-13-2001, 07:54 AM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
You don't need to push in the clutch to engage 4 hi. All you need to do is ease up on the gas pedal and shift firmly and gently into gear. I've shifted on the fly in all gears from a 5 mph to 65 mph pulling a loaded trailer in 6 inches of snow. The t-case is designed to be shifted on the fly into 4 hi. To shift into 4 low, you must be stopped, as you have to move the shifter through neutral to engage it. If you have automatic locking hubs, just shift and go. If you have manual hubs, they can be locked in, and you can be driving in 2 wheel drive, and shift on the fly when you want to.
by Osburn
Is this the way the atlas tcase works? On any np case I've always been able to shift into 4hi or 4 low at a dead stop. In fact, to get into 4 low I thought it was recommended to be at a full stop.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #6 of 6 Old 10-13-2001, 10:03 AM
osburn
osburn's Avatar
I know the manual says you can shift at that speed, and I've heard of others doing it. But, knowing that's a chain driven lightweight aluminum housing, yowsa, I could never stomach doing it.
I think you're right about going into low though. Now that I think about it, I really don't remember ever having any trouble getting into low on the 231. But on the Atlas, yeah, you need to be rolling a little to shift into low.
Matt Osburn
Score 1032
osburn is offline
Is it a bad thing to drive in 4 wheel drive moonlight TJ Wrangler Technical Forum 29 02-08-2010 09:33 PM
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 10:58 PM
how do i fix my 4 wheel drive - when in 4wheel drive only one wheel turns c-wag YJ Wrangler Technical Forum 3 06-01-2009 10:45 AM
No 4 wheel drive!!! help! mudproneyj YJ Wrangler Technical Forum 5 12-31-2008 07:41 AM
is my 4 wheel drive on? cmcgover YJ Wrangler Technical Forum 6 11-04-2007 04:26 PM
