4 th Gear sputtering - JeepForum.com
post #1 of 7 Old 05-01-2013, 10:01 PM Thread Starter
booboowv77
Ok I have an 89,4.2, MC2100, 5 speed, hei distributor, SOA w/ 4.10 gears. The problem is when I shift into 4 th gear the motor seems to start sputtering although it is at 2000 rpms after shifting which is the same rpms as the other gears after shifting. Does anybody have any ideas what to check?
I have adjusted the timing from 10-14 BTDC and have adjusted the fuel mix to max vacuum and then some with no real changes. It's not the clutch because the motor just seem to be sputtering. I have also adjusted the vacuum advance which is run straight off the manifold. The only other thing I can think of is maybe the jets in the carb need to be changed. what do you guys think?
GOOGLE IS YOUR FRIEND!!!
Just my toy!
89 YJ, Fresh 4.0, ax15, SOA w/410's, and about a million other things! :)
Built not Bought #759
booboowv77 is offline
post #2 of 7 Old 05-02-2013, 06:33 AM
Fenix85182
Fenix85182's Avatar
It's only in 4th gear at 2,000 RPM? Does it do it at any other gear at the same RPM? Does it stop if you rev over 2,000 RPM in 4th gear?
I'd assume a fuel delivery issue, but if it only happens in 4th gear, I'm not sure. Maybe you only actually notice it in 4th gear?
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
post #3 of 7 Old 05-02-2013, 07:16 AM
Siva283
That just doesnt make sense. Are you sure it doesnt do it in other gears just less noticably?
Ask me how I know...
Siva283 is offline
post #4 of 7 Old 05-02-2013, 10:18 AM Thread Starter
booboowv77
It may be doing it slightly in 3rd but first and second really seem fine. it does seem to even out when it hits 2500+ rpms or so.
Just my toy!
post #5 of 7 Old 05-02-2013, 10:59 AM
Siva283
When is the last time you did a tune up. Whats the condition of the spark plugs?
Siva283 is offline
post #6 of 7 Old 05-02-2013, 01:54 PM Thread Starter
booboowv77
Just did the HEI swap in the fall with cap, rotor, wires, plugs are still perfect.
Just my toy!
post #7 of 7 Old 05-02-2013, 05:26 PM
Fenix85182
Fenix85182's Avatar
Maybe it's less about the RPM and more about the throttle position? Could it be that around 2,000 RPMs you happen to be hitting the gas harder in 4th gear than in other gears?
I haven't worked on a carburetor in these Jeeps in years now, but I would think a clogged fuel filter, clogged jet, or incorrect ignition timing could be the problem.
