4" Rough Country lift, Brake Lines Holding me up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4" Rough Country lift, Brake Lines Holding me up
Offset Tie Rod Kit From RuffStuff!The Original 3/8" Ruffstuff Diff Cover!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-27-2014, 10:08 AM   #1
OGCrunches
All right ladies and gents, first time posting on the forums!
I am installing a 4" RC lift on my 95 yj, I'm from Illinois so rust is our enemy. The two torx bolts holding the brake line brackets won't budge and I'm stuck...
I'm looking at options, either be gentle and cut the bracket and just rebolt it to the shock tower, or suck it up and drop the money on some extended lines.
Any suggestions??
OGCrunches is offline   Reply With Quote
Unread 02-27-2014, 10:28 AM   #2
bashbro
Mine were stuck as well when i did my lift. I cut off the bracket, drilled a new hole and used a self taping screw to remount.
1989 Jeep YJ
2.5 - AX5 - 4" RC lift
MY BUILD THREAD: http://www.jeepforum.com/forum/f22/m...build-2004265/
bashbro is offline   Reply With Quote
Unread 02-27-2014, 10:29 AM   #3
OGCrunches
What did you cut it with?
Unread 02-27-2014, 11:09 AM   #4
OGCrunches
Just opted to drill it out! Now the treck continues
Unread 02-27-2014, 11:52 AM   #5
yjluv
I did the same as the above post and it worked for a while. Cut mine with a dremmel. Later on I added braided steel lines and love them.
yjluv is offline   Reply With Quote
Unread 02-27-2014, 12:27 PM   #6
OGCrunches
Hey yjluv, what lines did you use? I've heard a lot of good about the jks ones as well as crown industrial ones
Unread 03-01-2014, 08:39 PM   #7
yjluv
Crown. They work great and look good too.
Unread 03-02-2014, 11:22 AM   #8
fratis
fratis's Avatar
At 4" you really need extended lines anyways.
-insert meaningless out-of-place political diatribe-
fratis is offline   Reply With Quote
Unread 03-02-2014, 12:59 PM   #9
OGCrunches
Yea i figured, my first time running a lift so im getting the feel of it. Im going ahead and replacing all of my break lines because theres some rust here and there, then ill invest in the extendeds.
