4" rough country lift - Page 2 - JeepForum.com
post #16 of 26 Old 04-28-2011, 10:29 AM
69moparman
I recently installed the RC 4" lift on my 90 Sahara. Had to cut some of the stock bolts, so be prepared to run to the hardware store for replacements. As said earlier, get grade 8 bolts. One of the things I added to the project was quick disconnects for your front sway bar. Ya, ya, but I drive my Jeep daily on the road, so I like the anti-sway bar action. One word of advice, though, when the instructions tell you to re-torque the bolts after 100 miles - DO IT! Those Nylok nuts they supply with the kit do back off for some reason. I lost two while wheeling for the fist time after installing the lift. I also upgraded the shocks. While you're under the Jeep installing the t-case drop, it might be a good time to replace your tranny mount. They're cheap, and you're under there anyway. I bought the stainless steel brake hoses for the front and back, rather than messing with those relocation brackets and taking the chance of kinking the hard lines. I did use the relocation brackets to fabricate stand-offs for the front brake hoses to keep them from rubbing the tires on full lock.
Good luck with your project!
Mark
69moparman is offline
post #17 of 26 Old 04-28-2011, 01:33 PM
Nasmith1
I would recommend heavy duty upper arms. Maybe a heavy duty track bar as I bent these items. I used a rustys track bar and rough countrys x flex uppers as I plan to install these arms everywhere eventually. I run 34 inch ltbs with no problems. The stock ones will probably be fine, but I'm really hard on my things.
3 xj's - 1992 k2500 diesel - 1992 corolla (doubled my money..... after I blew it up) - 1995 yj - ***1997 Jeep TJ***
Nasmith1 is offline
post #18 of 26 Old 04-28-2011, 01:34 PM
Nasmith1
Oops forgot what forum I was in. I wish I would have done the 4 inch kit rather than the soa I did on my yj. It was a super pain. My bad.
Nasmith1 is offline
post #19 of 26 Old 08-23-2011, 11:06 AM
jesusfreakiamhe
my 90 YJ with 4" RC lift and 2" shakels and 36" I Rocks.
It took me and my buddy 7 hours to do this lift. having to grind off 4 bolts was the major set back
jesusfreakiamhe is offline
post #20 of 26 Old 08-23-2011, 07:15 PM
soonermatt
Mine took about 8 hours only because we wasted time with the track bars and sway bar. The picture includes 1" body lift and 1" shackles.
soonermatt is offline
post #21 of 26 Old 08-23-2011, 07:36 PM
Virjeep
Just did mine, new kits come with upgraded shocks. Took me about 7 hrs by myself. It was about 100 degrees, or I could have gotten it done sooner. Used a sawzall to cut rear shackle to frame bolts as I replaced them with greaseable ones. Pretty happy with outcome. Impact wrench sure made things alot easier.
Virjeep is offline
post #22 of 26 Old 08-23-2011, 07:46 PM
clarkjdg
clarkjdg's Avatar
Originally Posted by Feetwet View Post
Bolts and nuts for the frame mount ends of the springs were not included with my RC 4" Lift kit.
I ended up having to cut off all 4 as they were frozen to the old spring ends.
I forget the specs on those but I want to say 9/16 x 4 1/2"??
Some guys got replacement grade 8 stuff from Lowes, etc, but
I went to the dealer for them.
4pcs. J4007547 BOLT HEX 17014001 $7.20ea.
4pcs. 152350 NUT NONE 17015030 $4.56ea.
Total $47.40 + tax.
Yeah I had to do the same thing, so when I got finished I ordered the grease able bolts I dont wont to do that again.
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline
post #23 of 26 Old 08-23-2011, 10:53 PM
deathtrap
mine went on easy, no rust. took me and the father in law about 4.5 hrs with air tools and proper pitman arm
puller.
deathtrap is offline
post #24 of 26 Old 08-23-2011, 11:58 PM
nightmoves
puller.
your lucky mine took forever. i had to cut practically all of the bolts off whith a grinder.
SunDevilJeeper: kinda like masturbating behind the soda machine at costco or something. just sayin.
nightmoves is offline
post #25 of 26 Old 08-24-2011, 11:00 AM
cplayer5
Took me and a buddy a little under 7 hrs to do mine this weekend (lots of beer breaks!). A little trick we found if you come across a frozen main spring eye bolt seized, take the nut off of the inside first, then push the shackle end of the spring all the way to the ground and hold it there, put a breaker bar and socket on the bolt and pull like hell, it will come loose. We had two that were frozen and both came free using this method. A stated earlier, an impact really speeds things up.
cplayer5 is offline
post #26 of 26 Old 08-24-2011, 04:06 PM Thread Starter
srdart67
I decided to go with the BDS kit. Got a hell of a deal on it and it seemed like a better lift. But I wont know until next spring as it will be installed over the winter. Thanks for all the replies.
srdart67 is offline
2000 TJ w/ Rough Country 4" Lift, 2" Spacers, 35" MT BAJA MTZs roughskinjrz TJ Wrangler Technical Forum 22 02-05-2011 10:10 AM
Rough Country 4" Lift vs. Tuff Country 4" Lift reecep14 TJ Wrangler Technical Forum 3 07-29-2010 02:25 PM
Rough Country or Tuff Country 2.5" Lift? bballard1227 YJ Wrangler Technical Forum 7 09-23-2008 06:55 PM
Anyone run the 6" rough country lift? dwillz07 TJ Wrangler Technical Forum 17 10-30-2007 10:46 PM
4" Rough country lift anything else?? MATTPH77 TJ Wrangler Technical Forum 12 09-19-2007 07:54 PM
