4 inch rough country install and review - JeepForum.com
post #1 of 12 Old 09-24-2011, 05:57 PM Thread Starter
YJ_89
I installed a 4 inch RC lift last weekend and thought I would make a quick review of it so far. To start I ordered it on Wed. 9/14 and got it in Fri. 9/16. I opened it up to check everything and noticed the sway bar links were missing. After a quick phone call they sent them right out and I got them in on Tuesday. I was very pleased with the customer service I received and would definitely order from them again based on that.
On to the install. I work at a shop and have access to lift and all kinds of tools, but I decided to do this at home over the weekend with just basic hand and air tools. I started Saturday night after work and just got it on stands and the front sway bar and shocks off before it started getting too dark. On Sunday I got up and started on it around 10 with some help from my cousin. Everything actually went very smooth and only had problems on the right rear spring bolt on the frame. It took about 15 minutes with a hammer and pry bar to get the bolt out. All in all it took about 8 hours in my driveway on jack stands and that includes changing the front calipers after breaking a bleeder.
I did not have a pitman arm puller so I still have the stock pitman arm on for now and I also removed the front sway bar because I didn't have the links as of install time. Ive been driving it back and forth to work all week with a couple light wheeling trips and it doesn't drive too bad I'm thinking about removing the track bars and seeing how it feels but am undecided right now. The ride is a little bouncy but not as bad as I thought it would be and the RC springs seem to have some pretty good flex with the front sway bar off definitely a lot better then stock. I currently only have around 100 miles on the kit 50 with 31's and about 50 with 33's and am very happy with it so far. Ill update after I do some more wheeling with it but as of right now I would definitely recommend it.
Heres a couple pics from before during and after the install. I wish I would have got more during but only had my DSLR and didnt want to get it greasy. Before was on 31's and after was on 33's.
YJ_89 is offline
post #2 of 12 Old 09-24-2011, 06:42 PM
superj
dude, throw those track bars away!!!
i will never tell a person to toss their sway bars but track bars are a no-go. the leaf springs keep the axles centered and the track bars try to push the axle to the side when flexing so they are constantly fighting each other
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 12 Old 09-24-2011, 06:47 PM
phil1330
1964 CJ5
LOOKS MO BETTER..x2 on the trac bars
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
post #4 of 12 Old 09-24-2011, 06:52 PM
superj
ha ha ha, you took the same part of the steps off i took off. looks better like that too
superj is offline
post #5 of 12 Old 09-24-2011, 07:53 PM
jeepyj13
looks good and yes ditch tracbars. dont need them on leaf spung jeep.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #6 of 12 Old 09-24-2011, 08:52 PM
Cooter92YJ
I just got one question. If Wednesday was 9/14 and Friday was 9/15, WTF happened to Thursday??
Cooter92YJ is offline
post #7 of 12 Old 09-25-2011, 02:39 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sometimes you just gotta skip to Friday. Or sometimes to 1700 hrs.
Luck Favours The Prepared
Anticanman is offline
post #8 of 12 Old 09-25-2011, 06:41 AM
castorriver
Can someone post a pic of the YJ tracbars??
I'm thinkin about doing the RC 2 1/2 lift.
castorriver is offline
post #9 of 12 Old 09-25-2011, 11:18 AM Thread Starter
YJ_89
I was thinking about pulling the trac bars this week when I get a chance at work. Should I pull both of them or just the front? As for the sway bar being off Ive always drove it carefully and so far I really don't feel that much of a difference without it, but now that I have the links I might but it back on with some discos when I pull the trac bars.
In the 3rd pic its the bar that is unbolted to the left of the shackle.
YJ_89 is offline
post #10 of 12 Old 09-25-2011, 11:22 AM
Cooter92YJ
Yea, I wish that could happen with the work week
YJ89, nice lookin YJ. The black you've added really helps the yellow pop
post #11 of 12 Old 09-25-2011, 12:07 PM
superj
i pulled both at the same time when i first heard of it (i was hesitant also but i couldn't think of a logical reason to keep them). the ride improved dramatically. since then, i toss those as soon as i get another yj
superj is offline
post #12 of 12 Old 09-27-2011, 07:43 PM Thread Starter
YJ_89
I got a chance today at work to get under it and pull the track bars off and could already feel that the ride felt much better just driving home. I was a little hesitant at first but I'm glad I did now. Now to take it to some trails tomorrow and really see the difference.
YJ_89 is offline
rough Country 4 inch X lift install asa TJ Wrangler Technical Forum 47 01-02-2014 07:16 PM
Rough country 4 inch BigCasino TJ Wrangler Technical Forum 1 08-02-2011 08:07 AM
rough country x series review leukus TJ Wrangler Technical Forum 4 05-08-2009 11:38 PM
looking for a rough country 6" sua review sitdwnandhngon YJ Wrangler Technical Forum 5 04-12-2008 12:04 PM
Needed: Review of Rough Country 3" lift Slider_88YJ YJ Wrangler Technical Forum 6 07-21-2003 12:10 PM
