4 inch lift with no SYE? - JeepForum.com
post #1 of 15 Old 04-25-2013, 05:31 PM Thread Starter
Campsen
Am I going to need an SYE kit with a 4 inch lift? Idk what type of lift I'm going to order, I have 33x10.5's. an SYE kit with a new driveshaft angle is a huge turnoff, I can't afford that. I'll drop the transfer case if I have to but I've heard that some people still had to do SYE after the TC drop. Let me know if any of you have a 4 inch lift with no SYE, or whatever size lift you have on your 33's.
Campsen is offline
post #2 of 15 Old 04-25-2013, 05:41 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
A 1" t-case drop is seldom enough to eliminate the vibes of a 4" or taller lift. Sometimes adding a 1" MML (motor mount lift) will be enough when combined with a t-case drop but even those two combined are not always enough. So for that much suspension lift, a SYE & CV driveshaft is the better way to go though that would mean saving up for a little longer.
A solution to the SYE/CV driveshaft need would be to instead install a 3" suspension lift plus a 1" body lift to give you the 4" of clearance recommended for 33" tires. For that, a 1" t-case drop is usually (but not always) enough. When it's not enough, adding a 1" MML will usually do the trick.
Getting
Jerry Bransford is online now
post #3 of 15 Old 04-25-2013, 06:18 PM
MetalMountainGoat
I had a 1 inch t case drop on my jeep with a 3 inch lift, and still had some pretty good vibes coming from the drive line. Every Jeep is different, but in my case a SYE was needed even with just a 3 inch lift. Plus, a SYE opens up even more possibilties down the road, i.e. tummy tuck.
MetalMountainGoat is offline
post #4 of 15 Old 04-25-2013, 06:32 PM
larjeep
You will never know for sure until u do it. But they case drop should be enough to start with.
DO IT ALL, AND THAN SOME!
larjeep is offline
post #5 of 15 Old 04-25-2013, 07:14 PM
blubaru2002
I had a 1 inch TC drop back when I had a 4 inch suspension lift. I still had mild vibrations when accelerating from a stop. The vibes were never bad enough to toast a u-joint though.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #6 of 15 Old 04-25-2013, 08:31 PM
jsbeith
I run a 4" Pro Comp on my 2002 TJ. I used the Skyjacker TC drop kit and it completely got rid of my vibes. I am about to swap in D44's f/r and that will require shortening my driveshaft(s). I will probably need to do the SYE with a Tom Woods driveshaft at that point.
Lift it and see if you get lucky like I did with just a TC drop kit.
Good luck either way you go.
2002 TJ 4.0L 5 speed NV3550, NP231, 35" MTZ's
jsbeith is offline
post #7 of 15 Old 04-25-2013, 08:32 PM
sjones26573
*sigh* I feel like this is one of the most asked TJ tech questions out there.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #8 of 15 Old 04-26-2013, 07:19 PM Thread Starter
Campsen
I have a YJ though, I posted this in the YJ tech forum
Campsen is offline
post #9 of 15 Old 04-26-2013, 07:20 PM Thread Starter
Campsen
IDK why it posted in the TJ forum though.. Do you think it's different since I have a YJ?
Campsen is offline
post #10 of 15 Old 04-26-2013, 07:25 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to YJ Tech.
Wheelin98TJ is offline
post #11 of 15 Old 04-26-2013, 07:28 PM
BlaketheSnake
BlaketheSnake's Avatar
I'd put one in if I was gonna do any real wheeling.
If not keep some gear oil and a spray paint or glass cleaner cap and duct tape in the jeep just in case.
I've given help to two Jeeps that needed these items before.
Blake
Tread lightly or we all will be tree hugging hikers!
BlaketheSnake is offline
post #12 of 15 Old 04-26-2013, 09:00 PM Thread Starter
Campsen
I think I'm gonna do a 2.5 inch suspension on my 33's with tube fenders, $450 for a cv driveshaft and SYE isn't worth it to me. What do you guys think of that? and thanks for moving it to YJ tech
Campsen is offline
post #13 of 15 Old 04-26-2013, 11:14 PM
jokerchief462
My Tom Woods shaft was $309 to the door got the SYE kit on sale $169. Installation was a couple hours.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #14 of 15 Old 04-27-2013, 08:29 AM
sptrmike
sptrmike's Avatar
I have 4inch lift in mine with tcase drop, had very mild vibes but what i noticed was tcase seal and rear pinion seal were'nt holding up. the problem was after putting in the lift the drive shaft was to short. i called tom woods and spoke to a tech,i was told there should only be about 7/8 of an inch of the slip yoke shaft exposed with the vehicles weight on the suspension. i had just over 2 inches. they wanted to buy the sye and drive shaft set up they have ,but i went with the standard stye shaft instead, they told me i could possibly still have vibes. for the money difference i took the chance. i measured my shaft per tom woods web sight and added 1/4 inch. the reason i added the extra i ask them at tom woods what size shaft i should have with my actual measurement,and i got two dims with 1/4 inch difference, so i went to the longer side. i believe shaft with shipping was 200.00. that was over 53,000 miles ago no more vibes no more seals leaking. was i just lucky? i dont think so
sptrmike is offline
post #15 of 15 Old 04-27-2013, 10:34 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sye is around $160 and find a cv driveshaft off the front of a xj and have it cut and balanced.
It takes more work and less money than you thought.
Luck Favours The Prepared
Anticanman is offline
