4 hi prob - JeepForum.com
post #1 of 17 Old 06-26-2013, 12:37 PM Thread Starter
Jrodriguez1993
4 hi prob
When im out wheeling i come upon some steep hills. I out it in 4 high. It starts good going up the hill then dies down as i get further. I have to push the clutch half way in to keep it going. it Only happens in 4 high tho. 1st gear is what i had it in. 4lo works great on steep hills. Any advise? .
if you are telling you self you cant before you have even tried, you are a failure.
Jrodriguez1993 is offline
post #2 of 17 Old 06-26-2013, 12:39 PM
1998zj
Go up the hills in 4 lo. You are going to burn up your clutch pushing it in half way to keep the RPM's up.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #3 of 17 Old 06-26-2013, 12:47 PM Thread Starter
Jrodriguez1993
I know i will burn up my clutch thats why i use 4lo. But that doesnt solve my problem for 4hi...
Thanks for the obvious...
post #4 of 17 Old 06-26-2013, 12:52 PM
squarelite
You quite obviously don't have the power to run the hill without the gear reduction of 4 low. The high range 1:1 ratio requires all the power of the engine and doesn't rely on the lower gearing of low range.
squarelite is offline
post #5 of 17 Old 06-26-2013, 12:52 PM
JWBooth
JRod, bro, that's what 4 Low is for.
Please Note: My actual location is a lead box in Sassafras Cove.
-Proud Co-Founding Member of the Dirtbag Brotherhood
-Ringleader of the WhiteTrash Circus.
**LONG LIVE 4-LOW**LONG LIVE 4-LOW**LONG LIVE 4-LOW**
JWBooth is offline
post #6 of 17 Old 06-26-2013, 12:53 PM
grandboost98
Maybe 4hi just isnt enough to make it? I know my jeep wont do most hill climbs or obstacles in 4hi, just doesnt have it in her. 4low is where its at with the 4banger
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #7 of 17 Old 06-26-2013, 01:21 PM
Specter1911
Sounds like your not geared low enough. I'm running 3.07s and I have the same problem with mine.
Specter1911 is offline
post #8 of 17 Old 06-26-2013, 02:43 PM
Siva283
You have the 2.5 same as I do. Its a great engine it will take a beating but it doesnt have the power of a V8. You need to put it in 4lo its rare that I even use 4hi I just put it right into 4lo. In 4lo youll climb a tree with no probs. Just put it in 4lo and go.
Ask me how I know...
Siva283 is offline
post #9 of 17 Old 06-26-2013, 05:25 PM
g_oneill
I had the same issues, way better since the gear change. I always hated going into 4LO. did not want to always lock up the front end. Went from 4.10's to 4.88's and put in an ARB. Well worth the money I spent. It took me a year to collect the parts. Now I have traction with the back steering with the front and the gearing to climb a lot of hills in 4HI. I should mention I do have the 4 banger.
g_oneill is offline
post #10 of 17 Old 06-26-2013, 06:35 PM
Siva283
The front is locked in in 4hi the same as 4lo.
Siva283 is offline
post #11 of 17 Old 06-26-2013, 06:42 PM
bigbossd1030
This is true. The axle locks either way.
Your engine just don't have the kahunas for the climbs you are trying to do. They are all right above. You need to do them in four low, no two ways about it unless you regear.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #12 of 17 Old 06-27-2013, 09:02 AM
g_oneill
I can lock the ARB in the back have some great traction of two wheels pushing the car and leave it in 2HI. Works great on steeper hills with loose dirt on top of hard pack where speed is needed to climb and I may have to turn sharp at the top.
g_oneill is offline
post #13 of 17 Old 06-27-2013, 10:23 AM
mtber7828
Does anyone run there 4 cyl. (Standard shift)Jeeps in 4 low, sometimes in 2nd or 3rd gear? Will this hurt the gears? I've owned an old Toyota pickup w/ 4 cyl. And ran it a lot in 4low in 2,3,4 gear. Never seemed to have any problems but it was only a bush truck.
mtber7828 is offline
post #14 of 17 Old 06-27-2013, 10:39 AM
1998zj
I run mine in low and put it in whatever gear I need. I have never had any problems.
1998zj is offline
post #15 of 17 Old 06-27-2013, 10:46 AM
Siva283
^^^^This 4lo second gear takes me everywhere in my 4banger. I only need to use first if it is a really really steep hill and I have several passengers with me or my trailer loaded up for a week long camping trip.
Siva283 is offline
