Quantcast 4 Cylinder Fuel Injector replacement? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4 Cylinder Fuel Injector replacement?
Truck-Lite's New LED Headlamp SeriesCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Old 03-01-2009, 10:27 PM   #1
YJake
YJake's Avatar
I was wondering what other fuel injectors are compatible with the one on my 91 2.5L YJ?
There are TONs of 6cyl injectors out there but I don't think they are compatible. If they are, somebody please tell me.
I'm going to do the electrical test to the lame injector to see if it will click or not. If not, I need a new injector stat. I know it's not the wire that's bad because I tested it and got a steady light on my tester (The pointy screwdriver thing with a lightbulb in it). I also pulled the injectors out and the first one was teh only one that didn't have gas on the tip. Therefore, I either have a bad ground on that wire, or the injector is toast.
Are there any other vehicles that use the same injectors?
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline   Reply With Quote
Old 03-02-2009, 12:58 AM   #2
TA-YJ
Check this site out. You have to register, but they have tons of stuff about 4bangers. Theres a sticky all about different injectors too. Most people just use the 4 hole 19# Ford Design III that came off of mustangs and other cars w/ the same engine.
http://www.4bangerjp.com/forums/
TA-YJ is offline   Reply With Quote
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
