4 cylinder with cold air intake... any noticed improvement? - JeepForum.com
post #1 of 23 Old 04-27-2013, 06:49 PM Thread Starter
Campsen
Would I notice any significant change in acceleration or mpg in my 4 cylinder with a cold air intake? Is it worth 180 dollars?
Campsen is offline
post #2 of 23 Old 04-27-2013, 06:57 PM
gunshw301
Mpg might improve a bit because your wallet is lighter.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #3 of 23 Old 04-27-2013, 07:41 PM
4.7stroker
You will notice you wallet is lighter and the engine will be a little louder.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #4 of 23 Old 04-27-2013, 07:53 PM
Xpress
The 4 cylinders air and exhaust have been tuned to allow as much airflow as possible already, same for the 4.0. No point.
All about that unibody life.
Xpress is offline
post #5 of 23 Old 04-27-2013, 09:10 PM
plym49
No and no.
plym49 is offline
post #6 of 23 Old 04-27-2013, 09:19 PM
zte87
GIVE IT THE ONION
zte87's Avatar
I used to run one and really only notice more noise from it.........I went back to the stock setup!
zte87 is offline
post #7 of 23 Old 04-27-2013, 10:16 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Originally Posted by plym49 View Post
No and no.
This x2
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #8 of 23 Old 04-27-2013, 11:08 PM
ThomasYJ
No. If you want true cold air, do the 98 windstar intake modification and pull air from the cowl.
at the end of the day you'll still have the 2.5L, so you're kinda screwed either way lol.
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #9 of 23 Old 04-28-2013, 12:14 AM
imstillatwork
I wouldn't go that far...it's by far the worst flowing engine I've owned. Nothing about it is tuned for flow, it's purely cheap manufacturing.
imstillatwork is offline
post #10 of 23 Old 04-28-2013, 08:05 AM
Xpress
Then why, when one installs a higher flow intake, and a higher flowing exhaust, does the horsepower output not increase? That's because it's already as open and flowing as possible.
Xpress is offline
post #11 of 23 Old 04-28-2013, 08:37 AM
ThomasYJ
Forget the CAI.... just boost it. It's been done before plus with the smaller engine you'll have room for an intercooler.
The Toy:93 YJ
The DD:00 F250 7.3
Build:
ThomasYJ is offline
post #12 of 23 Old 04-28-2013, 08:50 AM
roadyrob
1987 YJ Wrangler
the intake and exhaust are designed to provide enough airflow to the engine as designed, they are not "already as open and flowing as possible"
if you modify the engine internals then modifications to the intake and exhaust help.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #13 of 23 Old 04-28-2013, 11:20 AM Thread Starter
Campsen
thanks for letting me know it's a waste of money. do you guys have any suggestions on cheap and easy mods to gain engine performance?
Campsen is offline
post #14 of 23 Old 04-28-2013, 11:39 AM
roadyrob
1987 YJ Wrangler
heres some interesting reading.
http://www.jpmagazine.com/techarticl..._power_adders/
IMHO any motor can be made to perform better if your willing to spend some money and do the work, but in the end a v8 swap will probably be cheaper and LOTS more fun.
roadyrob is offline
post #15 of 23 Old 04-28-2013, 11:39 AM
Luuca
Luuca's Avatar
You are pretty much at the top of your performance without a huge time and money investment.
Read this: http://www.jpmagazine.com/techarticl...r/viewall.html
or search 4.0 engine swap on the YJ forums.
YJOTM never
Luuca is offline
