4 cylinder axles in 6 cylinder 1995 Yj - JeepForum.com
post #1 of 14 Old 03-08-2011, 04:14 PM Thread Starter
jm1125
I recently purchased my second Yj. It's a 95 sahara 4.0 5 speed. I am tired of gear ratio problems with bigger tires. Is it an option to get 4.10s out of a 4 cylinder and bolt them up to my sahara? It seems like a cheap easy option rather than an 8.8 swap or re-gearing my currents axles. Are there any problems i would encounter? Thanks
jm1125 is offline
post #2 of 14 Old 03-08-2011, 04:24 PM
dillonjm
2013 WK
Yes, it is an option. They are the same axles.
However, depending on size of tire, it may not be a great idea to bolt another d35 in the rear. You'll get mixed opinions here, I fall on the side of thinking its not worth it to put time or money into your current or another d35.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 14 Old 03-08-2011, 04:29 PM
86YJSEANVA
1986 YJ Wrangler
as long as you dont go crazy wild when you wheel or have a lead foot it will be fine unless your gunning bigger than 35's get some chromoly shafts and call it a day it will end well unless your hard on it. its also an easy swap compared to say an 8.8
rugginTJ01;9379588]yeah, driving a happy meal on wheels during crazy wind is so much fun :laugh
talentjeep;8785973] I'll go ahead and add cardboard to my regular maintenance regimen. Originally Posted by Diamond-x Didn't the 'check shock' light come on?
86YJSEANVA is offline
post #4 of 14 Old 03-08-2011, 07:01 PM
linusb
axle swap is def way to go. it's easy work. 8.8 isn't tough to do, you just need someone to help weld if you can't do it yourself.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #5 of 14 Old 03-08-2011, 07:11 PM
NHfireLJ
NHfireLJ's Avatar
And with the right 8.8 you might find one with a LSD, and disk brakes...
$250 for my 8.8 plus the welding etc...
Had originally bought a set of D30 and D35 for $250... to do the same thing you are thinking..
Do it right the first time...
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #6 of 14 Old 03-08-2011, 07:37 PM
mightybg
that was close, I thought for sure this one was going to turn into a D35 fued-a-thon again.
mightybg is offline
post #7 of 14 Old 03-08-2011, 07:42 PM Thread Starter
jm1125
Thanks guys. Ok one more question, is there a formula to figure out how close to stock your new gear ratio will bring you? What ratio would I need to bring a jeep with 35 inch tires back to stock?
jm1125 is offline
post #8 of 14 Old 03-08-2011, 07:49 PM
RikRotorhead
4:10's will be close.
What year axles are you going to swap in?
There is a difference in axles by year. The brakes are different size and the brake lines are different on the earlier YJ years. They changed them in mid 1990. The discs are different too not that that matters, but if it is an axle out of an earlier YJ make sure to get the brake lines with it.
Experience. I put a '95 d-30 in my '88 YJ. Fortunately I gave my old axles to my son for his '90 YJ and we just swapped brake lines.
Just FYI.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #9 of 14 Old 03-08-2011, 07:53 PM
dillonjm
2013 WK
If you're going to regear anyway, taking 35's into account, my personal opinion is 4.56's for a DD, 4.88's for a trail rig.
4.11's will get you back close to a 3.07 / 28" tire ratio, but with the added weight of the tires, plus extra drag of the aerodynamic brick being higher in the air, I'd err on the lower (numerically) set of gears. This also takes into account my view that 3.07s are weak for a stock setup to begin with (which is why I believe TJ's had a 3.73 option in the Sports).
That said, if you're just trying to do this on the cheap, you could slap a 4cyl D30 front in with a 4.10 ratio 8.8 and that would be a nice budget combo where you can save a grand by not having to regear.
dillonjm is offline
post #10 of 14 Old 03-08-2011, 08:15 PM Thread Starter
jm1125
Thanks again. Last question, is the stock ratio on a 95 4.0 5 speed always 3.07. I've seen people say there was a 3.55 ratio on the manual too.
jm1125 is offline
post #11 of 14 Old 03-08-2011, 08:16 PM
linusb
4.11 gears with 35" tires and a 4.0 do a good job. you won't win drag races but you can pull 5th gear up hill.
linusb is offline
post #12 of 14 Old 03-08-2011, 08:33 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Use the calculator at www.4lo.com to see what kind of results you can expect.
Max
Sent from my HTC Incredible Droid
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #13 of 14 Old 03-08-2011, 08:40 PM
MJMPC
From the FAQ
What gears do I have in my Jeep?
I4 Automatic - 3.73:1
I4 Standard - 4.10:1
I6 Automatic - 3.54:1 (normally)
I6 Standard - 3.07:1, 3.54:1 or 3.73:1 - must verify with the tag on the axle or by pulling the differential cover and reading the numbers stamped in the ring gear or by counting revolutions of wheel versus driveshaft.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #14 of 14 Old 03-08-2011, 08:41 PM
RikRotorhead
3:55s were an option. There is a tag on the diff cover that will tell you what you have.
Mine had 3:55s
RJC#512
axle swap , gear ratio , sahara , YJ
95 4 cylinder axles into 6 cylinder Jeep? jon_gilbart YJ Wrangler Technical Forum 9 02-16-2011 02:37 PM
1995 YJ brake master cylinder question Bigdaddy YJ Wrangler Technical Forum 8 01-10-2010 05:07 AM
Removing center console lock cylinder from latch cylinder Dstompe TJ Wrangler Technical Forum 11 06-27-2009 07:01 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 08:37 AM
1995 YJ Clutch Master Cylinder lange1313 YJ Wrangler Technical Forum 2 08-04-2004 02:43 PM
