4 cyl engine issues - Page 2 - JeepForum.com
post #16 of 18 Old 04-16-2010, 11:54 AM
EABiker
Originally Posted by cjapgar View Post
was able to check the coolant sensor and cold it read 12 ohms, got dark before i could get to the iat
also tried running it without the iat hooked up and it ran pretty much the same
12 Ohms looks bad; too low. I found a resistance vs, temp chart online fo the coolant temp sensor, and 12 is not even on it. The correct range looks to be from 185 Ohms @212 F to 3.4K @ room temp.
EABiker is offline
post #17 of 18 Old 04-17-2010, 10:42 AM Thread Starter
cjapgar
cjapgar's Avatar
It may have been 120 I'm still not a pro with the ole multimeter
Originally Posted by Que89YJ View Post
Does it run any different between cold and when its warmed up? Does it happen at idle or when you are accelerating? Backfiring and missing is a timing issue related to sensors. Make sure you read the right temp sensor. The one you want to read is in the front of the engine on the thermostat housing. Clean out your throttle body and your IAC.
it runs the same either way warm or cold but moreso when accelerating
_______
/l ,[____],
l---L []lllllll[]-
()_)-()_)--o-)_)
Bacon is meat candy!
ΜΟΛΩΝ ΛΑΒΕ!
cjapgar is offline
post #18 of 18 Old 04-18-2010, 01:01 PM Thread Starter
cjapgar
cjapgar's Avatar
so did a little more pokin around to day and the coolent sensor is def low so i guess ill replace that,
where is a good place to pick up that and the iat online, couldnt find them on advance or autozone.
_______
/l ,[____],
l---L []lllllll[]-
()_)-()_)--o-)_)
ΜΟΛΩΝ ΛΑΒΕ!
cjapgar is offline
4 cyl. engine issues cjapgar YJ Wrangler Technical Forum 16 05-08-2009 09:09 PM
engine issues.. Patriot64 TJ Wrangler Technical Forum 10 04-11-2009 08:33 PM
98 TJ bad engine issues aquaholic_ TJ Wrangler Technical Forum 12 12-07-2008 06:21 PM
89 yj engine issues. Peterkalidonis3 YJ Wrangler Technical Forum 2 10-06-2006 12:53 PM
engine issues JSBlu974X4 TJ Wrangler Technical Forum 4 08-06-2006 06:08 PM
