4 cyl engine issues - JeepForum.com
post #1 of 18 Old 04-05-2010, 02:16 PM Thread Starter
cjapgar
cjapgar's Avatar
4 cyl engine issues
so within the last few days my engine has started running a bit raggedly.
The idle is at about 800, and both idle and neutral rev sound normal.
however when in gear, it is really choppy and i can relate it to the baseball card on a bike tire. Changed the plugs and nothin changed.
Gonna check the ignition coils as soon as i have the time.
what else should i be checking.
to clarify it is only noticeable when in gear.
_______
/l ,[____],
l---L []lllllll[]-
()_)-()_)--o-)_)
Bacon is meat candy!
ΜΟΛΩΝ ΛΑΒΕ!
cjapgar is offline
post #2 of 18 Old 04-05-2010, 02:24 PM
provinT13
If it's only there when in gear I would start with the transmission, drive shafts, u joints, and t-case
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #3 of 18 Old 04-05-2010, 02:24 PM
MJMPC
See if you have any codes showing.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 18 Old 04-05-2010, 02:25 PM
RebuildRookie
Is that the sound you hear coming from the exhaust or is it a clunking or ticking sound coming from the engine?
I'm a more proactive person.
You spray the ants before they get in your house.
You plant the crops before you starve.
And you keep the terrorists in check before you get your *** blowed off.
RebuildRookie is offline
post #5 of 18 Old 04-05-2010, 02:28 PM Thread Starter
cjapgar
cjapgar's Avatar
will be checking the tran fluid later, but what all should i be looking for there?
no codes but the non-existant ac
well you can kind of feel it in the pedal, so i dont think its the exhaust, plus checked it out and it looks fine.
so update: checked out the ignition coil : primary was 1.9 high, and the secondary was 12.4 right on would the primary be causing this problem?
_______
/l ,[____],
l---L []lllllll[]-
()_)-()_)--o-)_)
ΜΟΛΩΝ ΛΑΒΕ!
cjapgar is offline
post #6 of 18 Old 04-06-2010, 10:37 PM Thread Starter
cjapgar
cjapgar's Avatar
so talked to a car guy and he said the ignition coil is fine, so i picked up wires and a fuel filter. The more i think about it i think its a fuel issue
_______
/l ,[____],
l---L []lllllll[]-
()_)-()_)--o-)_)
ΜΟΛΩΝ ΛΑΒΕ!
cjapgar is offline
post #7 of 18 Old 04-07-2010, 12:29 AM
provinT13
I really don't see how something making a grinding and chattering noise can be a fuel issue if you're not getting any codes and your engine is running fine in neutral and at idle. Drain/change your trans and t-case fluid. Stick your finger in there and feel around for any metal or gunk that may have gotten in.
post #8 of 18 Old 04-11-2010, 10:10 PM Thread Starter
cjapgar
cjapgar's Avatar
been diagnosing some more and can say its not the tranny, def either the fuel or ignition
its running real rough, and occasonally back fires, with lots of vibs from non ignited gas or somthing
if i dont get this soon ill have to hit up a shop
_______
/l ,[____],
l---L []lllllll[]-
()_)-()_)--o-)_)
ΜΟΛΩΝ ΛΑΒΕ!
cjapgar is offline
post #9 of 18 Old 04-12-2010, 05:34 AM
EABiker
Grab an ohmmeter and check your sensors; make sure the coolant temp and IAT sensors are reporting the correct air and coolant temps to the ECM. If they are bad, your mixture will be way off and could cause these issues. The IAT should be around1-2K Ohms I believe, and the coolent temp should be under 1K on a warm engine .
EABiker is offline
post #10 of 18 Old 04-12-2010, 05:08 PM Thread Starter
cjapgar
cjapgar's Avatar
how exactly do you go about testing those, my hanes book says "beyond the scope of the home mechanic"
can i just remove the wiring harness to see if the problem stops? and where exactly are these sensors?
_______
/l ,[____],
l---L []lllllll[]-
()_)-()_)--o-)_)
ΜΟΛΩΝ ΛΑΒΕ!
cjapgar is offline
post #11 of 18 Old 04-12-2010, 06:03 PM Thread Starter
cjapgar
cjapgar's Avatar
was able to check the coolant sensor and cold it read 12 ohms, got dark before i could get to the iat
also tried running it without the iat hooked up and it ran pretty much the same
_______
/l ,[____],
l---L []lllllll[]-
()_)-()_)--o-)_)
ΜΟΛΩΝ ΛΑΒΕ!
cjapgar is offline
post #12 of 18 Old 04-16-2010, 10:57 AM Thread Starter
cjapgar
cjapgar's Avatar
Bump...
10char
_______
/l ,[____],
l---L []lllllll[]-
()_)-()_)--o-)_)
ΜΟΛΩΝ ΛΑΒΕ!
cjapgar is offline
post #13 of 18 Old 04-16-2010, 11:09 AM
EABiker
Either of the 2 sensors should measure around 1k-2k (ish), when warmmed up. I installed a 1.2K resistor in the iac harness until the sensor I ordered came in . The engine ran 95% perfect, (which was at least 50% better than before!). My original IAC sensor measured 300K, which said the temp was around -40F !
EABiker is offline
post #14 of 18 Old 04-16-2010, 11:17 AM
xdgt03
bad crank position sensor, bad map sensor, bad fuel injector
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
post #15 of 18 Old 04-16-2010, 11:38 AM
Que89YJ
Does it run any different between cold and when its warmed up? Does it happen at idle or when you are accelerating? Backfiring and missing is a timing issue related to sensors. Make sure you read the right temp sensor. The one you want to read is in the front of the engine on the thermostat housing. Clean out your throttle body and your IAC.
Que89YJ is online now
4 cyl. engine issues cjapgar YJ Wrangler Technical Forum 16 05-08-2009 09:09 PM
engine issues.. Patriot64 TJ Wrangler Technical Forum 10 04-11-2009 08:33 PM
98 TJ bad engine issues aquaholic_ TJ Wrangler Technical Forum 12 12-07-2008 06:21 PM
89 yj engine issues. Peterkalidonis3 YJ Wrangler Technical Forum 2 10-06-2006 12:53 PM
engine issues JSBlu974X4 TJ Wrangler Technical Forum 4 08-06-2006 06:08 PM
