4 cyl engine compatibility ? - JeepForum.com
 1Likes
post #1 of 16 Old 10-27-2013, 04:23 PM Thread Starter
Bergy1
Will a cj 4 cylinder out of an 84 or an 86 work with a yj(90) 4 cylinder? I have a friend with a 90 that has a bad bottom. I have access to a 4 out of a cj with good parts. Can these be mixed up for parts?
Thanks
Bergy1 is online now
post #2 of 16 Old 10-27-2013, 04:31 PM
jokerchief462
You have to look closely at engine mount bracket holes and the front if the block for accessories. They have been the same basic block for years.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 16 Old 10-27-2013, 04:42 PM
ddferdt
Don't some states frown upon older engines in newer cars?
ddferdt is offline
post #4 of 16 Old 10-27-2013, 04:55 PM
jokerchief462
Oh yes but I have no idea which ones other than CA which has a law for everything.
If you use the basic block and bolt all the old stuff on to include the emissions stuff how are they going to know other than chasing down a casting number.
The jaw keeps folks from getting around the emissions equipment for the model year if the vehicle.
With that said if all is still installed at the finish what's the problem. None that I can see.
So you use the stepped long block and bolt all the 1990 stuff back on. Nothing to mess with in wiring or ecu and should be legal and pass any inspection.
The block doesn't know any different it only does what it's told.
The biggest problem is mount homes with the different casting series.
post #5 of 16 Old 10-27-2013, 05:28 PM Thread Starter
Bergy1
Our state doesn't do emission testing, block checking, smog checking, or any other green peace checking:-)
post #6 of 16 Old 10-27-2013, 05:30 PM
ddferdt
Lucky you, bought mine with the cat deleted and it won't pass inspection unless I put one on -_-
ddferdt is offline
post #7 of 16 Old 10-27-2013, 05:32 PM
ashland82391
This seems like a huge down grade. Won't you be going from fuel injected to a carburetor?
bruinjeeper likes this.
ashland82391 is offline
post #8 of 16 Old 10-27-2013, 05:41 PM
jokerchief462
The compatible part you are looking for is the bare long block. No downgrade. Strip it and bolt all the original equipment back on. An engine block doesn't know the difference.
post #9 of 16 Old 10-27-2013, 06:03 PM Thread Starter
Bergy1
Jokerchief, that's the info I was needing. Thanks!
post #10 of 16 Old 10-28-2013, 10:47 AM
Que89YJ
The 84 was the first year of the AMC 2.5L. You need to make sure that it is no earlier then 84. The GM Iron Duke was used in the CJ before 84 and it will not bolt up without some work.
Que89YJ is offline
post #11 of 16 Old 10-29-2013, 07:54 AM Thread Starter
Bergy1
K. I will check on that
post #12 of 16 Old 10-29-2013, 08:40 AM
schaef89
I just recently found out that my 89 has a 2.5 from a 85 in it after I looked up the casting number. All my TBI stuff fits and I wouldn't have known the difference if I didn't look it up
89 YJ S, 2.5L/AX-5/NP231
99 WJ Limited, 4.0L/42RE/NP247
93 YJ, 4.0L HO/32RH/NP231 - Sold
schaef89 is offline
post #13 of 16 Old 10-29-2013, 05:15 PM Thread Starter
Bergy1
It's out of an 80, so I guess my friend is back to looking for another engine.
post #14 of 16 Old 10-30-2013, 07:57 AM
Que89YJ
The 80 would be the gm engine. There are a lot of 2.5 engines out there.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #15 of 16 Old 09-29-2016, 08:26 AM
LenVino
Hey guys and gals, sorry to bring this one back from the dead..
I'm trying to take advantage of a deal on a 4cyl engine. I need to replace a blown block on a carb'd '89 YJ. Can I use a 4cyl block from a '94? If I get the whole unit, fan to bellhousing, what can I keep and what needs to be reused from the carb'd 4cyl I currently have?
Thanks in advance for your time and consideration with all this!
Always the best,
Lenny
LenVino is offline
