4 bbl or v8 - JeepForum.com
post #1 of 15 Old 02-01-2014, 04:13 PM Thread Starter
89yjislanderr
4 bbl or v8
hey folks. as my profile states, i have a 4.2 5speed. lookin to get more power. my first thought was a 4 barrel carb, but after buying one and a new 4 barrel manifold, ill have spent the same, if not more, than i wouldve on a used v8. any thouhts?
89yjislanderr is offline
post #2 of 15 Old 02-01-2014, 05:43 PM
Que89YJ
There isn't enough air flow for a 4bl. Do the nutter bypass.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #3 of 15 Old 02-01-2014, 05:46 PM
superj
I have a 4 barrel and will be doing a v8 sometime because the i6 still isn't as fun as I like. I have an auto tranny though
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 15 Old 02-01-2014, 06:06 PM
YJ4LIFE
It's tricky deciding which fork in the road to go down. I've stuck wiht the 4.2L and will keep it as long as it lasts and use the money I didn't spend replacing it doing other things for now. You might want to do a 4.0L head. I didn't because my 4.2L head was in good shape but it would have made my EFI swap WAYYYY easier.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #5 of 15 Old 02-01-2014, 06:06 PM
Que89YJ
Super, you are running a 4-bl on a 4.2?
Fault codes:
No Start:
Que89YJ is offline
post #6 of 15 Old 02-01-2014, 06:39 PM
roadyrob
1987 YJ Wrangler
a few of us run 4 bbls. I have a holley 390cfm, along with a few other mods. it performs real well for a 6 cyl. OP, you can find deals on the manifold on ebay and craigslist. you need to check prices on a v8 swap, no way you can do it for 8-900.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #7 of 15 Old 02-01-2014, 07:25 PM
Que89YJ
Quad 390? I thought the 4-bl would flow way too much gas. I have never heard of a 390 Holley! I love this forum, I learn every time I'm on here .
Fault codes:
No Start:
Que89YJ is offline
post #8 of 15 Old 02-01-2014, 08:09 PM
jsawduste
2006 YJ Wrangler
First to go is the 3.07 gears. Add some gear to the poor thing so it can at least start to stretch it`s legs a bit. It will never run well they way it is geared now.
Darryl, Ron up is St. Helen is running an 82 CJ7 with an offy intake and Edlebrock 4 BL. Played with the jetting and vacuum springs and it runs pretty darn good.
jsawduste is offline
post #9 of 15 Old 03-04-2014, 06:56 PM
1987_yj
1987 YJ Wrangler
I run a Holley 390 on an Offy. I have a dead spot I am trying to overcome. Can you point me in the direction of some threads to help with this? I have changed a wealth of carb parts. I am stuck.
1987_yj is offline
post #10 of 15 Old 03-04-2014, 08:10 PM
roadyrob
1987 YJ Wrangler
this might help
http://www.junkyardgenius.com/holley/tune01.html
roadyrob is offline
post #11 of 15 Old 03-04-2014, 08:52 PM
superj
I am running a 450 holley but the 390 is run by a few local guys on aftermarket intakes and they really like them
superj is offline
post #12 of 15 Old 03-07-2014, 02:01 PM
zeus87gn
1987 YJ Wrangler
http://www.holley.com/TechService/Library.asp
Pay attention to the Power Valve section
You may need to change it to a faster one - I had to to overcome my stumble
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #13 of 15 Old 03-07-2014, 02:03 PM
zeus87gn
1987 YJ Wrangler
^^ This ^^ is the first problem
Then concentrate on your tune and get the ignition fixed up and bypassed
(if it hasn't been done already)
zeus87gn is offline
post #14 of 15 Old 03-09-2014, 10:22 AM
1987_yj
1987 YJ Wrangler
Thanks! I have replaced the power valve with stock size but I will check the vacuum again and compare
1987_yj is offline
post #15 of 15 Old 03-09-2014, 10:36 AM
0III0forlife
1987 YJ Wrangler
I too run a Holley 390 CFM. After going from the Carter to a Weber, to a MC2150, then getting pissed and putting on an Edelbrock 600, I opted for the Holley.
But it requires some add-ons to perform well...Such as fuel pressure regulator, and some springs on the floats to prevent cutout when climbing a hill. Knock on wood, it has been performing to my liking for over a year now.
0III0forlife is offline
